What is wrong with op-amps?
I very much doubt its due to the slew rate directly, that's just a marker in this case that the part you love hasn't the usual LTP input stage and hence exhibits less sensitivity to out-of-band grunge at its inputs. I'd double check your decoupling - have you observed hygiene in keeping power and signal grounds separated?
Oh Yes, separate power ground return. 2 oz copper traces. Russian 0.033 - 0.056uf k71 styrenes (what ever I can get at an earthly price) as close to the power pins as possible. Next to those 1uf pp. Also 220uf panasonic FM//1uf PP from pos rail to neg rail to help with supply common mode. I could go on.
Just because of this thread I put a pair LM4562 in my last Mouser order. I gotta' say life would be a lot easier noise testing these when compared to LT1358's. The LM4562 was 5db quieter. The vanishingly small distortion spec is an eye opener! But........
So I put them in my newest rev. of LCRMKIII pcb. Burned it in over night. They were not bad. But they can't capture subtle sonic cues like a faster opamp can. It wasn't like being in the back of the concert hall but it was like having a slight head cold.
a significant amount of musical drama that the LT1358 can translate is just not there with the 20v/us LM4562.
So knowing this, if anyone has any other suggestion of a dual opamp that can beat out my 600v/us LT1358, since you guys believe the high speed slew rate just can't possibly make any difference in the T&M would logic of audio design, let me know.
Jan? Scott? anyone? I'm open.
Morinix, are you really using the LT1358 with 10Vpp input? if not, then maybe you should check that nice chart with "slew rate vs Input level" and let us know the slew rate at the actual input level.
Indeed - it doesn't pay to get too hung up on the numbers. But then I'm repeating myself 😀
Seems slew rate has a fair amount of misunderstanding connected with it - its a large signal property and if your opamp is slewing (and its not an I/V converter) then something's wrong somewhere...
Save
The part that does not line up with your thinking is that every time I used a faster device, be it in a design of my own or a modification of an existing unit that same result happens. This has played out since the early 90's when I was exposed to this philosophy.
Well since I have nothing to listen to nor do I know what "musical drama" is I could only go by the numbers and recommend an even noisier op-amp with 9000V/us. What in fact is the difference between T&M and taking a single number off of a datasheet as a measure of performance.
BTW there's a 40,000V/us 6 GHz op-amp coming soon.
DIP adapters... and what are those ceramic caps for? If the polystyrenes are your decoupling caps...
Except you're just plain wrong and too ignorant to see it. The LT1358 is not even a faster device in all cases. Even Kirchhoff (!!) is trying to explain to you.
It's a lot slower with a MM cart level input. No similar chart on the LM4562 that I could see on a quick scan. I would guess that it would also be much slower than the 15v/us (OUCH!) minimum on the spec sheet. So if the LT1358 is sub 100v/us on a millivolt input what would the SR be on the LM4562 with a millivolt input?
I don't know. Nor does TI care to tell us. They have some 10 pages of THD diagrams though. I guess their target market were those obsessing on THD 😀
And here, ladies and gentlemen, is one example where the measuring instruments come into play - for the right reasons. Where spec sheets are incomplete and / or innacurate.
They need to sell like anyone else. A mile long spec sheet will usually go unread.... until things like this happen.
Back to the mud slinging (let's not). The above statement shows a fundamental mis-understanding of what's going on. Both amplifiers are first order integrators so the input error signal and it's linearity vs rate of change of the output is what is important. Slew rate is an expression of the limit of rate of change of the output. Slew rate as a function of input (especially at the mV level) is meaningless.
You can do this on the bench with a high gain buffer measuring the input differential while reproducing a tri-wave, very educational. You even get to apply Kirchoff's law. 😀
