Hello xrk971
greetings did you try FH 11 version 1.05 sonals layout
warm regards
Andrew
I do not find the black and white from Sonal, he posted only the 1 pair power mosfet type...
Greetings🙂
I found it!Years ago(1990?) in the Elektor cmos preamplifier used cmos and op amp in input and out, as source switches.
I will try to find the boards.
Hello sownel
greetings which mosfet amp are you talking about
warm regards
Andrew
Greetings sir.
Post no 8105
work in progress ... preamp apex P30
Hello,
work in progress ... preamp apex P30 ...
Thanks to Alex mm and still4given, for help me ..
Hello,
Hello xrk971
warm regards
Andrew
No, I never made an FH11. Closest is CFH9 though - listening to it now. Very nice.
Hello,
Cant believe its diy etched PCB, really nice, congrats!
If anyone will order some boards of that preamp, I would buy a few from him(her).
thanks
im curious if tone control could be added.
thanks
thanks
I added the tone control circuit. Works well.
Hello,
Hi do you have pdf or layout.pcb file. thanks i want to build this.
I used a cmos cd4016 and/ or cd4066 with great success. You can't hear them in the circuit at 18v and 47k 47pf loading. CD4052 4*2 makes a great analog selector.
newer chips provide better resistance but it's moot.
I still have the 1024 step attenuator I made for fading tape recordings in and out.
Their only practical limitation is the rail to rail maximum input signal
Hello,
I answered you in private message..
Thank you
- 100W Ultimate Fidelity Amplifier
