What is wrong with op-amps?
SMPTE IM won't do any better than harmonic distortion, perhaps even worse. It used to be the standard for tube amps, but it only senses distortion of the 50-60 Hz waveform, not anything higher. uA741's, for example, did pretty well with SMPTE IM. CCIF IM (19-20KHz) could be VERY useful, however.
A few other faults with op-amps might include:
Optimal small signal resistor values depend on and is different depending on power voltage used. This also makes the datasheet example schematic accuracy, a rarity.
Ignoring the effectiveness of even the most simplistic power filtering in trade for promoting power noise rejection as a cure-all.
Optimizing these is considerably less convenient than advertised. I do wish there was room to fit a few more ccs in those little packages! The amount of labor to manually trim these, is not well documented. Instead, the datasheets (aka advertisements) tend to claim that one schema works for every task imaginable, same for every op-amp, even though that is not plausible.
You might as well ask for 9 legs and a ground pin.
Scott,
You are going to need 10 pins to allow the magic transistor capacitor to be connected! I just don't know how you could forget such an important connection.
Now if you add two more we can have a place to insert the carbon composition resistor in the VAS stage for even more improvement.
But I know the audio market is just too small for such a device...
Scott,
We also must include Tom Bearden's Motionless Electromagnetic Generator.
more on op-amps , possible fix
I thought a cerdip with nuvistor style socket piggyback might work.( like mostek/hitachi)
A better solution would be a monolithic device in cerdip with integrated 'tube' diff pair. The device matching pair would be incredible.
So the op-amp is a true hybrid with input stage grids etc. +- 24v is adequate.
Heater no problem , old art.
