What is wrong with op-amps?
I was really curious about this. 'Whats wrong with op amps' is an interesting question. Are there good responses buried in this thread?
The most useful responses are buried, but mostly surround the risk factors of bare foot/sock-only stepping on a PDIP package buried in your carpet. 😀
Otherwise, they tend to have really variable behavior when you drive them out of their rated specifications. Mind your input and output impedances and read the datasheet carefully. Ask for help if you get stuck. 🙂
And binomial statistics are evidently hard.
try not posting for a while, like a week - this is like running a FFT multiple times, it lowers the noise floor and increases the value of the data.
...frankly you're all pretty much acting like children, regardless of your job/retired from job/money/degrees, or anything else...
this is a waste of my time... later...
Got a good answer?
'Good' is rather a subjective word, I've got an answer which has worked for me. By which I mean that having identified the problem and then corrected it the sucky sound went away.
The identified problem in most cases was to do with the power supplies and the associated decoupling. To cut a long story short the output stages of opamps generate noise due to running classAB and this noise appears as signal-correlated ripple on the power supply. It often couples from the supply to the 0V signal reference. There are several ways to attack this, I can spell them out in more detail if you're interested?
None of the commercial pieces of kit using opamps that I've examined has made a distinction between 'signal ground' and 'power ground' in the layout. So first of all its important to separate these - signal ground can be considered to be 'clean' and hence no power decoupling must be returned via it. Groundfill is useful for power decoupling but less so for signal.
Secondly the feedback networks of opamps are often loading the opamps outputs unnecessarily. When JFET input opamps are used, these networks can be increased in impedance. Driving an easier load makes for lower PSU noise.
Third - output stage current source biassing can be employed in cases where feedback impedances have to be low because of noise concerns. Linear Technology shows this technique in at least one of its datasheets.
Indeed they don't, and if one doesn't understand what words like "statistics" means, then you can conclude that data and evidence regarding the topic at hand are not likely to be offered, nor will you be likely to have a useful and intelligent discussion.😀
There is a Cornell professor and his former grad student (now at NYU) whom would have a ball with the late development of this thread.
So you've measured the impact and you know for a fact that the return currents are flowing where they can disturb the circuit's operation?
A separate ground done improperly can be a dangerous thing and a good way to make yourself susceptible to RF and fail EMC testing.
Nope, its obvious from the topology of shared impedances that the return currents are going to be imposed on the signal ground. No need for measurements.
Yes, I agree.
ABX is only one possible format. There are many others.
You can set up actual listening tests on your own just to screen out what turns out to be incorrect from the get-go. If after that, you feel there's a there there, then write up what you did and put it out there for review and replication- honest researchers are completely transparent in that regard.
Or even if you don't:
"If you’ve made up your mind to test a theory, or you want to explain some idea, you should always decide to publish it whichever way it comes out. If we only publish results of a certain kind, we can make the argument look good. We must publish both kinds of result."
Cargo Cult Science
can't the opamp be kept in the class A range and stay out of the B stage or is that not possible with the opamps?
Yes it most certainly can, though it pays to watch where the currents are flowing when the opamps are running on balanced supplies. It tends to be easier to work out what happens with only a single ended supply. Here's what Linear Technology show in one of their DSs - see the JFET on the LT1115 output.
