Power Transistor Insulation
Which one of these would you prefer to insulate a T03 type transistor mounted on a heatsink.
Mica or silicon pad? I have a couple of spare silicon pads that I can use. So wondering if it would be worth using them instead of mica.
I wonder whether silicone pads like Sil-pad have aging problem and also whether it can be reused. What I meant reuse is if you remove the transistor and put in the new one, do you have to change to a new one.
I know you need silicone grease when using mica, grease dry up after a while and you have to redo it after many years. Does silicone pad have this drying up problem?
most, or maybe all, sil-pads need to be replaced after a first removal.
Grease does not dry up. Some of the volatiles may evaporate, but most remains even after prolonged high temperature.
What is used as the transport medium in the Thermal goops may not be grease. They may use a light oil with a very high proportion of volatiles. These could become "dry looking" but the remaining paste should still exclude air from the interface and thus give prolonged thermal performance.
Thermal paste should be renewed after first removal.
They are rigid and very brittle, and need a completely flat mating surface, plus spring (use a torqe wrench) or clamp loaded mounting hardware, or they WILL crack. Other than that it works great, very low thermal resistance.
I used sil-pads for my class A amplifier and no heat transfer problem.
I can understand if the sil-pad is screwed on for years, how about during the testing phase where you take the board on and off a few times, it would be too expensive to change the sil pad.
I searched and posted side by side comparation, which by the way showed mica + grease to still be better than the better silpads (they are not the same) by some 30/40% but don´t remember where I saved the data.
But it must have been either here or at MEF with a very distant third possibility at SS Guitar, so if interested do a search and it should appear.
Or compare data at the silpad site to standard mica grease yourself .
"Any thermal resistance data on mica and grease to compare? "
I generally figure around 0.3°C on a TO-3 (correctly applied).
Some sil-pads are lower °C, but those types can be quite expensive. They also can be used by lesser skilled operators.
Re-work and repair can be a costly thing with the one-use pads though.
I caught a repair operator reusing some pads at work (hey, they looked OK, right?).
Our customer returned goods involving a certain failure went down by 85% after this.
We use both sil-pads and mica + grease, depends on the design requirements.
Some pads have internal shields and a drain wire (to reduce capacitance effects).
Ive used alumina ceramic insulators about a dozen times now. With regular #4 screws and lockwashers. Zero problems, no cracking at all, and measurably, significantly better thermal performance than mica, which is better than silicone (I haven't measured Kapton insulators but theres data online indi ating they don't do much). The deramic filled or foil laminated silicone ones are said to do pretty well (haven't tested). The performance can be important if you're running class A and want to keep the device die temperature safe when the heatsink temperature goes high.
Alumina is a remarkably strong ceramic and not easy to break or crack. It does need to mount on a flat surface, but really, the surface needs to be flat on any heatsink if its going to work decently. Ive just used the as-received surface on black anodized heatsinks.
