This is a shared DIY project for non-commercial use.
The SG4 generates 4 low distortion, high accuracy sinewaves suitable for driving conventional audio power amps to create a multi-phase drive for turntable motors. The generator outputs a reference sinewave at 60/81Hz or 50/67.5Hz on the 0° pin. The 90° pin outputs an exact replica of the reference sinewave, but shifted +90° (Cosine) for driving 2 phase AC synchronous motors. The 120° & 240° pins output an exact replica of the reference signal, but shifted +120° and +240° respectively for driving a 3 phase motor. The SG4 is a sinewave generator only. You will need to add the necessary audio Power Amps and step-up transformers (if needed) to create the final signal to drive the motor. Low cost linear and class D amps are readily available on e-Bay and other on-line sources. Working with High Voltage can be dangerous. Do not attempt this part of the project if you are not trained in handling power electronics: Seek competent technical help if needed.
The PCB uses all thru-hole components for easy assembly, but some soldering skills are still required. The µP is a PLCC package but there is a socket for it on the board.
The project consists of a bare PCB, a parts "kit" available as a shared cart from Mouser electronics, a µP with the operating system pre-programmed into it and the on-line documentation you see here.
The PCB is available from OshPark PCB fabricators at the following link: https://oshpark.com/shared_projects/E5zXjeJd
The PCB is created in multiples of 3 for a cost of ~$45 or $15/board.
24-Feb-2022 The parts kit at Mouser has been updated to include the MCP101 reset controller that replaces the DS1833 part. The pin out of the MCP101 is the mirror image of the DS1833 so the PCB has also been updated to Rev C to reflect this. If you are using a Rev A or Rev B PCB, you must insert the MCP101 part backwards; the Rev C PCB does not require any change.
The parts kit can be ordered from Mouser Electronics: http://www.mouser.com/tools/projectcartsharing.aspx
Enter the Access ID code: 7A6A645FFA. The parts kit to build 1 PCB costs $32.34.
The pre-programmed µP is available in the US from DIYAudio member Seth Hensel via email: sethhensel (at) icloud.com. Cost will be ~$12 plus $8 handling plus shipping.
The pre-programmed µP is available worldwide from DIYAudio member ralphfcooke via PM. Cost will be ~£10 plus shipping.
The following documentation is available below to aid in construction of the project:
SG4 Schematic.pdf
SG4 Parts Locator.pdf
SG4 Assembly Instructions.pdf
SG4 BOM.pdf (Generic bill of materials with part references)
SG4 CART.pdf (Mouser cart with mfr's part numbers and costs)
SG4.zip (Gerber X274 files if you want to use your own PCB fabricator)
The SG4 uses a 20 bit DDS core implemented in software to generate the reference sinewave. Frequency resolution is 0.01Hz. Frequency range is 40.00-70.00 Hz for 33 RPM and 60.00-90.00 Hz for 45 RPM. There is an on-line video showing the frequency operation Here and a video for phase adjustment Here.
There are four 8 bit phase accumulators to generate the four phases. The reference signal is fixed, but the other 3 are adjustable in 1.5° steps ±15° maximum. D to A conversion for the 4 signals is done with 8 bit PWM at 18kHz. There are 4 LPFs on the board to convert the PWM signal to analog. The outputs are DC coupled, 5VPP and centered at 2.5VDC. Distortion is ~0.5% (-46dB) and frequency stability is 30 PPM.
Update: The firmware has been updated to version 1.02. A 7 bit linear taper attenuator has been added to ramp the voltage from 0 to 5VPP at start up when exiting standby mode. This should prevent the amplifiers from shutting down when first started as they will have time (~650mS) to overcome the core magnetization of the transformers. I also added a reduced output voltage mode, where the output voltage will automatically be reduced to a user programmed level after 5 seconds. The level is adjustable from 128 (maximum) to 64 (half voltage) in ~40mV steps which equates to ~1V steps at the transformer outputs.
19-Nov-16: I returned the phase adjustment to 1.5°/step. One of the peculiarities of using a 16 bit phase accumulator with an 8 bit DAC (PWM in this case), is the limited precision math can create different points where a carry occurs (and thus an additional phase step). For most frequencies, this isn't noticeable as the difference in phase shifts is usually in the mSec range. In certain cases, the math works out where it becomes quite noticeable and in the audio range where it could affect performance. Using a 16 bit phase accumulator in the SG4, a nasty phase spur will occur on either side of 81.92Hz, which is fairly close to the frequency needed for 45 RPM. The new firmware hasn't hit the field as of yet, so there will be no need to do another exchange. V1.02 will ship with the attenuator capability, but will retain the 1.5° phase adjustment of the original.
Users who upgrade to the new firmware should perform a Factory Default Reset after installing the new firmware.
28-Dec-2016: Just added the PCB files to OshPark for a Rotary Encoder to SG4 interface PCB. The circuit converts the 2 quadrature signals from the encoder to a single pulse train on the UP pin when turned CW and a single pulse train on the DN pin when turned CCW. The momentary push button switch of the encoder is connected to the STBY button of the SG4. This allows all of the normal operating functions to be performed by one rotary control.
The 1 inch square board uses all surface mount components in order to keep the size down. The IC is a CD4013 in SO14 package. C1 and C2 are both 0.47uFd Tantalum caps 10V rating in a 1206 size package. R1, R2 and R3 are not necessary if you use the Arduino Rotary Encoder which has the pull up resistors already on its PCB. If you use another encoder without pull ups, add the 3 resistors (all 10K 0805 size). Vcc is connected to the 5VDC output of the regulator on the SG4.
You can order the PCB here ($5 for three):
[url]https://www.oshpark.com/shared_projects/AbsVI39H[/URL]
The Encoder PCB can also be ordered with thru-hole component layout instead of SMT:
[url]https://www.oshpark.com/shared_projects/W6QWOCOF[/URL]
1-May-2017: Version 1.03 of the SG4 firmware reduces the lower frequency limit to 1.00 Hz for both 33 and 45 RPM. The reduced lower limit was needed for 3 phase BLDC motors, some of which require 20Hz for 600 RPM. If you are not using a 3 phase BLDC motor, there is no need to update the firmware.
16-May-2017: A DIY 3 phase amplifier project is now available to drive a BLWR172S-24-2000 or BLWS231S-24-2000 BLDC motor from Anaheim Automation.
It is not a universal controller and will only work with these two motors: 3 phase class D DIY BLDC motor drive amp
A suitable audio power amp and step up transformers are available here: 60-wpc-amplifier-diy-turntable-motor-drive
13-Dec-2021 The PCB has been updated to Rev B and the firmware has been updated to v1.04. These changes add the ability to use a 2 x 16 character LCD display that has an I²C interface PCB with a PCF-8574A interface chip. Version 1.04 firmware is backward compatible with the previous PCBs so an LCD display can be added to a previous build. The details of all the changes can be seen here: SG-4 Version 1.04 Update
It is important the LCD interface chip is a PCF-8574A and not a PCF-8574; the two chips work nearly identically, but have different address schemes. The new SG4 firmware will only work with the PCF-8574A addressing.
SG4 Schematic.pdf
Pyramid,
My deep respect, you did an amazing job.
Ralph, you can count me in for a PCB + Processor.
Hans
Hans
Subscribed! What's the deal with the uP? Is there stock of the programmed up? What's the cost likely to be?
Sent from my iPhone using Tapatalk
Thanks for the kind words. Hopefully the results live up to your expectations.
jrubins- DIY member bfg4wd will be stocking and distributing the pre-programmed chips. Still working on the details...will update as soon as it is all sorted.
I am in....
Count with me for PCB, programmed PIC and if possible a full parts kit.
Congratulations to Pyramid, I appreciate your efforts with the DIY community.
Jorge
Jorge
Thanks Pyramid, that must have been a lot of work.
I'm in for at least one PCB + parts. Anyone else in Aus. interested? I'm in WA.
Dumb question #1: How would you box it to get the display visible? Wouldn't U1 touch the case? I guess you could mount the LCD and buttons externally with a ribbon cable?
Kffern
Kffern
Kffern
Not a dumb question at all, the easiest way would simply be to add a socket for the display, and maybe either use pb switches with longer shafts, or, as you say, mount the pb switches remotely.
The display footprint is DIP16, so it could be raised up with a socket or a ribbon cable with IDC connectors could be used to mount it remotely. All of the buttons can be replaced with panel mounted versions, they are all SPST. The 33/45 switch needs to be a toggle switch, UP/DN/Stby need to be momentary.
The output pins are also on 0.100" centers so a header and cable could be used between the generator and the amps.
micros
Pyramid,
Thanks so much for your efforts.
To All,
The chips have been ordered, there have been questions about cost, I'm not doing this for profit. So far my investment is $6.04 ea. I will look into shipping options next. Also we have an offer from ralpfofcooke to handle distributing in the U.K.
You can P.M. me here, or email trotzted at gmail.
When we have a total cost the preferred method of payment will be paypal.
Ted
Pyramid,
To All,
Ted
bfg4wd ........ Also we have an offer from ralpfofcooke to handle distributing in the U.K. Regards said:Just to correct a couple of points, my a/c is ralphfcooke, and I'm happy to act as distributor for Europe and UK.
If anyone finds a nice enclosure, please post a link. I know ebay has tons of them, much nicer than the typical hammond plastic or metal.
I bought a used Wilson Benesch Circle turntable a couple of years ago. I read on a forum that it uses a Papbst motor, so I assume it is a 2 or 3 phase AC motor. I assume this sinewave generator and a small power amp drive the motor at much more stable rotation than stock?
Hi Hank,
First of all I would have a look under the turntable at the motor. If it's a Papst them the rotor is on the outside and is 3 phase. Any info you can read from the motor case will help determine exactly what you need.
I know it's a bit of a drag, but reading through the thread:-
http://www.diyaudio.com/forums/anal...-driving-vpi-synchronous-turntable-motor.html
will hopefully provide all the info you need
Good Luck
Good Luck
Thanks - I haven't looked at it as it's in a housing that seems glued down. In this WB manufacturing video you can see the motor at 4:06:
https://www.youtube.com/watch?v=LXNXJD5F0r4
I did read most of your linked thread.
Hi all, Just now aware of this thread. I'm all in on the generator, this is really great. Thanks to everyone for this, especially Pyramid. It must have been a lot of work, and a very generous thing to do. I have PMed bfg4wd about the UP. Now I'm looking into the board. I don't have any problem ordering 3 boards, however if someone out there has already ordered 3 and only needs 1, I'm interested in buying and helping with the costs. If not I'll buy 3, and offer the other 2 up for sale on this thread at cost. I'm ordering the parts now from Mouser.
twystd
twystd
- Analogue Source
- DIY 4 Phase Sinewave Generator for Turntable Motor Drive
