I am pretty novice about these.
I have a Logitech Squeezebox Touch and no DAC. I want to buy a DAC and use the Touch only as a streamer. Why do I need i2s? What advantage it would give me? What is reclocker? Do I need this too?
It is all very confusing for me. Can someone explain in plain language? Thanks!
Jencelo do you know google ?
I²S, also known as Inter-IC Sound, Integrated Interchip Sound, or IIS, is an electrical serial bus interface standard used for connecting digital audio devices together. It is used to communicate PCM audio data between integrated circuits in an electronic device. The I²S bus separates clock and serial data signals, resulting in a lower jitter than is typical of communications systems that recover the clock from the data stream. Despite the name, it is unrelated to the bidirectional I²C bus
https://wyred4sound.com/products/digital-converters/remedy-reclocker
Yes, I do. I have read before I posted my question but as I mentioned I wanted to have it in plain language. This is little too technical.
I am asking this. What will a re-clocker or another piece of equipment connected to Touch give me? What is it good for?
Re-clockers are good for transferring money without any jitters between buyer and seller.
Thank you for the reply. So, what you are saying is that people who uses re-clockers are wasting money. Did you try one before?
I never tried these things and I wonder if I am missing something. Can I improve the sound of my SBT? Dunno.
Thanks again.
Basically this sentence:
...is already untrue in the era of high speed serial interfaces. I.e. since around year 2005
