Musical Fidelity "The Preamp" - any good ?
The preamp works well. ( I own 2 of these and the Dr T's)
There are no obsolete parts in the preamp. (Also the output devices in the Dr T can be replaced by modern lateral mosfets although they very very rarely give trouble )
The preamp was built with poor quality electrolytic capacitors. If you want good sound these will need to be replaced with low esr electrolytic capacitors. Ideally Elne Simic.
Don
I'm using the phono stage of a Nuance preamp, going to a passive volume control and then to a Quad 405, like the setup quite much but wouldn't mind improving the phono stage. Should the MF have any better phono stage ?
Does it sound exceptionally good, to keep for a 150$ ? Unfortunately I cannot really listen to it, only check that it "works".
For 130 $ worth buying if only as a piece of " hi-fi history " and if in original working order an investment .
As for using it well , if it still works for how much longer without surgery ?
And has some " enthusiast " swopped caps etc without knowing exactly what they are doing ?
I could go on with what ifs but in 1982 it was an outstanding product , it's now 2016 thats a long long life for any original electronic component.
Most active pre amps add their own 'flavour' and one from 1982 probably wont be a stellar performer. There are some good diy options on here and $130 would get you quite a long way. If you don't need gain then a DCB1 with a component kit from teabag is a good solution for the outlay, especially since your in the states.
I had a Dr T and the Preamp back in the day. Replacing the plodding sound of Dr T with an Adcom made a huge improvement. The Preamp though was quite good. Still working after 30 years with cleaning of the selector switch and producing respectable sound.
A good passive preamp like an LDR optical volume control blows it away. If impedance matching is an issue you could add a buffer stage to your passive.
