Troels' Seas 3 Way Classic MkI vs MkII
car subs are a good example.
basicly most of them will work properly in the exact same box.
they are designed to do so.
you can find drivers that can be used interchangebly, the price tag and the brand name do not tell anything at all.
sometimes even if you have a datasheet, the spread in production makes it mostly not too usefull if you want to be verry scientific.
The reason why I decided to go with the 3 way bookshelf is the size of the room where I will be putting the speakers, which is small: 4mtrs X 5mtrs. I'm thinking a 3 way floorstander with a big enclosure for woofer will dominate & excite room modes more.
Troels Classic stand-cabinet with ~1.5cuft has F3~39Hz. For the same floor area, a floor-cabinet with 2.7cuft produces F3~28Hz with the same SB23NRX45 8" woofer. No crossover changes are neessary.
If your furniture style supports a floor standing cabinet, you can get the deep 28Hz bass the 8" SB23NRX45 woofer is famous for in no extra floor area. Low A on a piano is 27.6Hz.
Did someone think to do a 3 Way classic from Troels but without the mono brand factor when choosing the drivers ?
I surmise for instance in the ScanSêak version or the AUdioTechnology version mediums drivers to be the best, but about the bass units and tweeters ?
@ System 7 (Hi), any thoughts ? A biger enclosure with a sealed bass ?
Well sorry if OT, here we are not in the kit anymore while possibly be very close when mixing the brands' units !
cheers
I think you should always address the obvious weakness of a speaker to seek improvement with more cash or design.
In the case of the SEAS-3-Way-Classic, it is that the goodish underhung H1304-08 MCA12RC midrange is overworked on power handling, as illustrated in Boxsim's estimate below.
One obvious way to do that is to double up the midrange units in series, which Wharfedale did in their splendid room-filling E70. Simple filter conversion of doubling coils and resistors and halving capacitors in the mid circuit for the same SPL with a mere quarter of the individual excursion. Quite how you layout the drivers is moot. I'd favour inline MTM here set off to the side, rather than Wharfedale's sideways offset. Since 3kHz is 5 cms half-wavelength, hardly an issue.
As for bass, you could certainly do closed box (Qts = 0.5) with a suitable driver, but the H1288-08 CA22RNX (Qts 0.41) is not far off anyway.
Thanks Steve,
It could be cool if some brands like AE could send a bass driver with a high ebough Qt for a sealed enclosure while still having the lowest -F3 as possible (so without Linkwitz transform, but with the help of the room gain).
Unfornatully, hard to find a Pro driver which is made for sealed and a 30 Hz-500 Hz/800 Hz (in the case the ScanSpeak 10F medium is choosed - or the Seas ,SB Acoustic brothers.
... and without band pass sealed bass load 🙄!
All of that remember me each time Troels seems to prefer his OBL (open bafle wide bafle) design to his vented designs !
Totally OT this time, my apologizes to the OP.
Hi Linesource, do you happen to have the plans for that floor standing cabinet in the pic? thanks.
Thank you for sharing the comparison graph, I don't see a significant difference...I appreciate your help.
I don't understand sreten's remarks at all about Lynn Olson's bafflestep or Troel's diffraction considerations. Both look competent and considered to me. 🙂
But back to this 3 way. What 3 ways do well is go loud and undistorted, with flat power response, wide dispersion and good impedance.
I don't care for soft domes at all, and would prefer a metal tweeter here, a la Harbeth style. The H1212-06 27TBFC/G is a slot-in replacement for the H0881-06 27TFFC
Stepped baffle LR2 was a bit of a struggle to implement simply here, and the very shallow tweeter filter looks like one of those things you end up fiddling a lot with, as Joachim Gerhard did up to Kalasan 5 version, adding an Fs notch. TBH, I'd fancy the better power handling and lower distortion of the flat baffle version.
Troel's original flat baffle design is truly excellent IMO. Comparison below. Dotted lines are the original. Phase alignment is exemplary with either.
I am slowly arriving to this conclusion, thanks for the help.
It is a question for you to answer based on how you value things. TG considers the Mk II "better" and so if the extra cost is small and you are happy with the step in the baffle then that would seem the way to go. If the extra cost is not small then go for the Mk I.
Despite Troels doesn't like (for the moment?) Active and DSP, I'm asking myself if just a plate amp for the bass with DSP could mimic a sealed load with its good transcient and a smoother sealed -12 dB low end?
There is also a question, but maybe it's a myth : Cabinet which doesn't touch the floor has some space below it : better soundstage and some even say: subjective better bass sounding ????
Troels could also with the 3 Ways classic to have floorstanders with an empty cavity below the main load wich cab be filled with sand, bricks, what ever... which is not bad for the bass ever ! So did he stay with the cabinet shape to keep the advantages of a better soundstage ?
I'm gonna throw in another variable to the equation...I just learned last night that my wife will have a business trip to the Netherlands next month & she's asking me to tag along, I researched online and ScanSpeak drivers are cheaper there for some reason. I'm thinking I can bring an extra empty luggage, buy the drivers there & bring it home.
My question is: in your opinion, is the ScanSpeak 3 way classic Mark II better than the Seas or SB Acoustics versions?
If you want to construct a floor-stander using Troels Classic 3-way crossover you would maintain the width and exact driver location on the top portion of the front baffle, and extend the height such that the tweeter is at ~39" ear level. The cabinet depth can also be changed to achieve your volume goal. Change port dimensions based upon a WinISD simulation.
The pictured speaker is from post #26 build of the "Astasia" described here on diyAudio.
Astasia Prject - 3 ways loudspeakers:
Woofer: Seas - CA22RNX
Midrange: Seas - MCA15RCY
Tweeter: VIFA Vifa XT25TG30-04
http://www.diyaudio.com/forums/multi-way/140324-astasia-prject-3-ways-loudspeakers.html
===Shopping in Netherlands==still favor Satori Satori 16MWP @1700Hz
Several experts have moved to latest-and-greatest-tech 6" midrange like the Satori 16MWP from SB-Acoustics, adding the SB29RDC -C000-4 tweeter for a 1700-1800Hz crossover plus the SB23NRXS45-8 woofer. There are free designs like the Kalasan you can build. You might also favor the flexable use of separate TM & W boxes like Karios. TM Desk Monitor // TM-W floor stander.
.... I would like to see (an old discussion we read also in Johachim G SB Acoustic Monitor) : this Satori Midrange sealed with a low end sealed as well.... Hey Why not the 18" push-push you talked in a separate enclosure ?
For a 150 Hz to 1800 Hz sealed mid : does a Satori is better than an aluminium Visaton A200 (but it's a 8") ?
Could it be better than a vented mid ????
