Ultra-high performance, yet rather simple - hybrid and more!
Hi, attached are the schematics and the silk screens of the latest versions. I'm running them with +/-52V rails. D8 and D9 zeners are removed.
Valery
Hi Vizai I see the super pair at the output of the VAS but what is the use of it in VFA? in CFA it will increase the slew rate substantially but VFA dont you have stability issues in the circuit? Any sonic benefits of having the super pair in the current design?
Hi rhythmsandy,
The use of it is actually the same - high speed and linearity. TubSuMo front-end is very fast and low-distortion - one on my favourites.
In terms of stability - combination of the right base stoppers, local compensation and global compensation ensures unconditional stability of the circuit. It's been built many times, used with different output stages and never had stability issues.
See the measured performance with lateral MOSFETs:
TubSuMo with Laterals
as well as with non-switching NS-OPS:
TubSuMo with NS-OPS
If you're looking for a great sounding amp - the one with laterals is strongly recommended - ease of build and top performance.
Valery
When the tube is cold it is off so there is no feedback. You can see full rail at the speaker. The most important thing is that the tube has time to fully warm before the rest of the amp is engaged. I would still not run without some type of DC protection.
Terry, absolutely right. Input LTP needs some seconds to settle even when the filament is already hot enough.
In any case, I would never connect my speakers to anything DC-coupled without the proper soft-start/protection system. That's how the 21-st century board started 😉
Valery
I have tried using the ALF16N20W and they are very good. I do wan to know more about the NS OPS. How much bias have you used to get the low distortion at 20Khz. In general does the OPS switch with conventional simple EF driver? For the bias of 60ma per transistor?
NS-OPS is a EF3 with CCS-ed class A drivers and mechanism, preventing the output transistors from switching off when inactive. It runs at 65mA per output pair (3 pairs of MT-200 Sankens in total) and shows extremely low distortion - see the measured spectrums and THD / IMD numbers in combination with Vertical front-end here:
Vertical CFA + NS-OPS measurements
There are not too many amplifiers, showing 0.0007% THD at 20KHz (measured at 50W @ 8 ohm) and 0.0005% IMD 14+15KHz in the same conditions. This is a virtually "no distortion" amplifier.
Very low distortion of the OPS allows relatively low global loop gain in the amplifier (35-37db), still showing very good distortion performance. See X4 series of the low gain ultra-linear current-drive front-ends at the link above - combination with NS-OPS forms an outstanding amplifier with exceptionally natural sound. X4 JFET version is especially cool.
