Selling Zhou Fang’s remaining stocks including some very rare Toshiba transistors
Matched 2SK246/2SJ103.
Hi, Lyubin!
Maybe you can better provide Vgs matched sets at 1/2 of Idss.
Those condition are similar to a real working, so your matching would be a great option.
Also, due to transconductance difference between N- and P- devices you can go through EUVL's input stage degeneration sample, see attached article.
BR, Pavel!
  • JFET Degeneration.pdf
fab
Joined 2004
2sk2013y/2sj313y
Hi fab,
prices have been updated in the first post. thx
Thanks!
This is quite interesting for me.
From the IV curve you have posted it looks that they have about all the same vgsoff ( about 2v or so) since the data sheet indicates a range from 1.4 to 2.8 Vdc at 10 ma for grade y.
If that is so then I do not need matching since the shown vgsoff is perfect in my application. Please confirm the vgsoff value that is within about 1.9 to 2.1 Vdc or so.
Fab
Hi fab,
I did plotted Vgoff, I remembered it ranges from 1.8 to 2.2. I will show the plots:D
Thanks!
Fab
Hi Pavel,
Thx a lot for the great suggestions! Appreciate.
I can definitely and will be happy to provide 1/2 Idss matching, if anyone requests. It is not difficult to do, as i scanned the whole curve.
For the degeneration of the fets, I actually tried that. It indeed can help match Gm. One thing I did not mention in my previous comment is that the Vgsoff of k246 and j103 are quite different. Therefore, even we manage to match Gm, the two curves are still not matched due to different Vgsoff. The curves are more like parallel curves aparting from each other. I will show some plots later. If anyone is looking for Gm matching but not idss matching, I can certainly provide some.
Hi, Lyubin!
BR, Pavel!
fab
Joined 2004
Hi fab,
Hi
I Know for the plots you have provided here but is it for all of them of only a sampling done so far. Do you provide the IV plots with the parts ordered or a kind of certificate that they are all within a specific vgsoff range or IV range would be fine for me too.
Fab
Hi Pavel and those who are interested in this topic,
Here are some plots for degeneration of 2SJ103. I tried to use different resistors to decrease Gm of 2Sj103 which has larger Gm. By using a larger resistor, Gm can be matched to 2SK246, but Idss wont be matched due to Vgsoff difference between these two FETs :rolleyes:
Therefore, for 2SJ103/K246 matching, I have to sacrify Gm to get Idss matching...
Hi, Lyubin!
BR, Pavel!
Here are Vgsoff data from those FETs I measured. Pls take note I will not be able to make sure those I did not measure would have similar Vgsoff:)
Hi
Fab
Hi, Liubin!
Check your PM.
Suppose you need to degenerate both N- and P- devices on a different resistance.
Let me show you simple trick - start from parts with equal measured Vgs(off) and then match Gm's by degeneration, suppose this will resolve the issue.
And remember, you doesn't need full-curve matching! Only in a more or less region around working point - half of Idss.
Strongly suggest, none of us are using overloaded input stage.
fab
Joined 2004
Hi
Is it possible to order parts ( N and P channel) based on vgsoff between 1.8 and 2.1 volts?
Fab
Hi Patrick,
You are a true expert on this and know much more than I do:) this is a test rather than question, lol? Anyway, the operation point depends what ppl build. Current could be 50mA to 200mA for most amp, I think. However, if you want to operate it at higher current of 500mA with heat sink, I don't see there is any issue on this.
What do you think the operating point would be for most applications for 2SK2013/2SJ313 ?
Patrick
