The Pass Pub: The High-End Off Topic Thread
Ventricular Ectopic
......anywhere from every couple of days to once a month. I think it's called getting old.
........ really can have some twisted thoughts while wearing this thing, believe me.
Anyways, it comes off in a few hours and I'll know in a few days how things went. If this is my last post, then I guess it was more serious than I thought. :D
Cheers.
.........you are writing about your heart-rate? If not, that is pretty normal at your young age! ;)
Hope that it is found to be unlinked to anything serious.
Still off of the tobacco? If so then that is a big plus for you.
Official Court Jester
Joined 2003
ook
Joined 2003
Colortune is , by my understanding, intended (and good) up to 3K Rpm
and , certainly must easier to work with than repeatedly pullin plugs out
however - considering nature and history of my little bike - carb Keihin clone, most probably too lean from factory , but I tossed one carb and kept just one , with 1 to 2 Rebel manifold , K&N filter (mounted on proper length intake hose) , and new (read - more open) mufflers ........ it's logical that I must increase both idle jet and main jet ..... and tweak needle position
all that much faster with Gunson thingie than change-ride-stop-pull plugs out ....... change-ride-stop-pull plugs out ....... change-ride-stop-pull plugs out ....... change-ride-stop-pull plugs out ....... change-ride-stop-pull plugs out ....... change-ride-stop-pull plugs out .......
:rofl:
OK , for now - I have original 94.5 main
got from China 98,100,102,105,108
hour ago , I pulled 94.5 out and put 100
it's already better
it'll stay in , 'till I get Colortune
edit: and , it'll be handy for my V35 Guzzi and , hopefully, Suz Savage 400 engine , put in second Chinese chopp
