FU50 tube amp mods and schematic
Just bought an FU50 tube amp from china. These are apparently quite popular over there.
Anyway hoping to get some comments on the attached schematic. Any easy mods?
Dont know much about tube amps but can use a soldering iron
The usual requirement with a Chinese amp it to ensure that it is safe.
What voltage it the mains tranny specified for and is it giving correct output? (Measure not guess.)
Do components like caps and rectifiers have a safe working voltage above the maximum expected?
Is the wiring and earthing up to western standards and safe?
Do these, then you can improve it.
Wise words Colin. I can measure mains tranny output once I recieve it. Can also post photos of wiring etc. But how do I determine if the components have a safe working voltage other than trusting the print on the components? Which components would be best to replace just in case?
Checking what is printed on them is a start.
Power supply caps can be good one's to look at.
Then it's up to you and your budget what you change.
How about changing the circuit from UL to triode?
What would I need to do?
Disconnect the wire going from the output transformer to pin 3 on the FU50 tube. Insulate the end of the wire so that it cannot short out to anything else.
Connect a 100R resistor (value is not critical) from pin 3 (screen grid) to pin 6 (anode) of the FU50 tube.
Pin 6 of the FU50 remains connected to the output transformer anode lead.
All other connections remain the same. Adjustments may be necessary. These will vary, depending on what else is in the circuit.
