Fostex's new Fe103 Sol 8 50th anniversary Drivers?
Ha ha, fantastic thanks everyone! 'High Ratio vents' makes a lot more sense! 🙂
I'm now doing a bit of reading tonight to try and understand their advantages.
And i never took typing. You will note on yout keyboatd that T is next to R and Y is next to T.
Here are plans.
http://frugal-phile.com/boxlib/P10free/mFonkenSOL-0v8-090615.pdf
dave
Thanks Dave, VERY much appreciated!!
I see the photo you posted of the Falcon shows the port on the rear. Assuming the port dimensions are kept the same, would it be detrimental to move the port to the rear?
My drivers have turned up earlier than expected in Australia! I best get on with cabinets! They sure are cute little drivers!
Anyone can comment the SOL Freq. Response curve
Hi everyone;
Don't know if it is still interesting for anyone, I found the mentioned test of the german magazine HobbyHifi under the description of the SOL at an retailer:
https://www.hifisound.de/out/media/pdf.php?r=1RnPzlqw4KJmCKvdtg3bIGgLHsyE4phAAQBAKKi4RYQNx7FAG%2BSK88URH1eskcEvZpfks%2BuVY4vKDRimmmYw2Q%3D%3D.pdf
If there are some problems with translating this text I may help; PN me 🙂
Regards!
From the curve derived from the above reference(thks S4m) and another source I came across, I believe there is rise in the freq. response curve above 5khz to 20Khz from on axis measurement.
My question is does anyone find the freq. rise irritating if it not control via a Low Pass filter to remove it? If not how do you control it if not all.
