If he is going to use THREE Tweeters, then I have to ask - Why Three? Why not Two; why not four?
Five is right out!
Five handle enough power for PA, and the curvature limits interference to the vertical plane (inside the focal point).
Community had a model with a similar stack of four tweeters.
Hi DJK, I should still have a pile of KSN1016 which came with metal mounting frames and oddly, a parallel capacitor - what would have been the use of that cap? - IIRC the cap was similar in value to the self capacitance of the piezo element. One KSN1016 did 103dB/1M/2.83v on your transformer scheme with just a 1uF cap highpass - probably would be a bit more with a 2nd /3rd order highpass. That array might work on top of my RCA-Fan midbass with Gollehon midrange - if I ever feel well enough to get back to it.
M&K monitors with three tweeters, and push-pull subwoofer.
Some guy told me, some so-called Me geithain (top models) use 3 tweeters......
I think you are going to have to do better than that if you want us to help you.
musikelectronic geithain
http://www.me-geithain.de/index.php/en/highend/products/passive-loudspeaker
http://www.me-geithain.de/index.php/en/highend/products/active-loudspeaker
"ME 806 - The two-way concept comprises an 8-inch woofer system and a tweeter array of three vertically arranged 1-inch tweeter calottes"
Steve/bluewizard
Here is test with measurements of Me Geithain ME-180 with three tweeters. 14.000€/pair.
https://issuu.com/moizfidelity/docs/download
SoundStage! Hi-Fi | SoundStageHiFi.com - Aurelia XO Cerica Loudspeakers
Aurelia cerica uses 3 tweeters in a Waveguide. Works like magic imo.
Been thinking of playing around with some cheap drivers like BC25SC-55/04 Vifa 1″ tweeter | Loudspeaker freaks
Truth is i havent bothered as one tweeter can work that magic too.
Remembered reading on tweeter arrays with one driver in reverse phase. Took me a while to find the papers. It called Bessel array.
AES E-Library Effective Performance of Bessel Arrays
Here is more about it...
A Paul Kemble web page - speaker bessel arrays.
McIntosh used something similar.
SonicFlare - Hi-Fi reviews, audio events, show coverage, photos and more McIntosh XLS 320 and XLS 112 System Review
Sorry, i don't understand the whole Tekton spealer hype. They don't sound that good to me, at least the ones I've listened to.
hmm......
playing around with my 4 x tg9 3.25" full range driver array............
I think 3 tweeters (all run same signal) can work, if your ears stay exactly between the top and bottom tweeter.
https://www.soundstagehifi.com/index.php/equipment-reviews/642-aurelia-xo-cerica-loudspeakers
"The final thing to be aware of, and probably the most important, has to do with the Cericas’ vertical dispersion. As long as I remained seated, the Aurelias sounded like any well-designed, dynamic-driver speakers.............. But when I stood up, most of the mids and highs disappeared, leaving a sound that was incredibly dull. This has to do with the driver configuration"
So, if you can live with that, lower distortion is a good thing..............
Perlisten is using 3 tweeeters with some tricks
https://www.audioholics.com/tower-speaker-reviews/perlisten-s7t
https://www.perlistenaudio.com/
- Using three tweeters a ok idea?
