As far as I know, with 8 GB of RAM you will be able to achieve 0% sound degradation.
The best grade is the named "High class professional" and I am not sure if it is possible with 8 GB or we need 16 GB.
with 8gb you get "ZTUNE" enabeld
"High class professional" only with 16gb-32gb!
Dewy1
how this can be done-Im using laptop?hi
you Need more ram
4x4gb or 2x8gb for no Sound Degradation.
dewy1
one physical slot is still available-8gb ram maximumfirst look in the user Manual how much ram are supported
dewy1
can I expect less sound degradation and better performance with bughead?
when i right understand,then you have 2 Slots and one is free?
and each Slot 8gb Maximum?
also you Need a cpu with avx 2.0.
the last Version without this restriction is 7.27
dewy
dewy
I think second free slot can accept only 4gb so in the end 8 gb all togetherwhen i right understand,then you have 2 Slots and one is free?
dewy
and together Im thinking about ssd instead of hdd but Im playing from sd card can I expect some audio improvement anyway?
Bug head 7.90 x64 Release
http://oryaaaaa.world.coocan.jp/_userdata/package_20170106_Bughead_x64.zip
So unless I'm mistaken, you need: a 6th gen Intel processor with a specific set of features, plus 16GB of RAM, to play music.
Call me underwhelmed, but I can play fantastic sounding music on a PC with a 1.2GHz processor and 1GB of RAM.
I don't see how this has assumed the status of 'Best Player Eva!' from some very subjective listening.
Surely it's just your opinion, as is your favourite speakers, your favourite amp and your favourite food?
JAAT (Just Another Audiofool Toy).
I'll stick with Linux and MPD. Can't fault it.
+1 ...I am not disputing the sound quality but it is a 'niche' player, the hardware requirements are OT for most users...
Тhere are nice old version, for example 5.80 SQZ. Works with old hardware.
And sound is better than Linux and MPD. I did try a lot of hardware and software players ( Windows, Mac, Linux) and so far Bug Head is the best. And this is not only my opinion. Every time, when I try different software and hardware, I listen with friends and random guests.
Where can I get older versions of software, late 6.## early 7.## my cpu does not support AVX 2. PC i'm using is i5 gen2 with 8gb ram.
HeY! Where can I download this BugHead 5.80 SQZ version? Please post a link.
Greetings
P
https://drive.google.com/folderview?id=0B-HZf3I4Da03Nng0Zk9KTGNlT2c&usp=sharing
Versions above 7.27 only runs if your processor is able to run AVX 2.0 instructions, sixth gen Intel are capable.
Download the last version. If not work, copy these four files instead original ones.
This post had some older versions but appears to be gone now.
https://drive.google.com/drive/folders/0B-HZf3I4Da03Nng0Zk9KTGNlT2c?usp=sharing
hope this works
Install 5.80 version and replace the files in folder 7.27 and you get updated to the 7.27 if you wish.
- PC Based
- Bug head Emperor
