Maman Fume une Pipe
I recommend an anechoic rave chamber, 50 percent cheaper on your end.
Built-in loudspeakers, bluetooth, light show.
(Tired of life as we know it ? Swallow a couple of XTC pills, and hit the infrared firing squad switch)
noise abatement
Steven , my apologies.George,
Sorry I wasn't confused
I was wrong.
a man-crush on
Plutarch ? On the Face in the Moon (Part*1 of*4)
(4HTML Pages)
Kepler found it important enough to translate it himself.
There are some surprising ideas and theories among a lot of speculation there (A Philosophers symposium, what would you expect )
Plutarch had written numerous books with a more distilled collection of (his) past knowledge on planetary bodies and their motion
George
awaiting the measurements ...
Its a belief. Cant be measured.
Seriously though, there are many psychological studies on expectation bias and related phenomena. Just google.
(My wife is a psychologist - she understands all this stuff. I think Jakob and Myrreline [sp?] have some knowledge in this field)
George--I'll give it a read.
Good.
When you feel tired of his writings, there is always an Aristophanes comedy to lighten you up (with gusto)
George
Okay, so I think he's Buddha, second coming of Christ, Flying Spaghetti Monster, and Vishnu
i could only wish ...
now that the excitement, has subsided,
here it is -
james randi was amazingly,
starting a covert army/hit squad.
even more amazin,
was how fast his stuff was coming together.
made some very influential people very unhappy.
and they put a stop to that sort of thing.
but content, please.
as received.
from above.
you know.
from the stars.
above
p.s.
you probably want context too ...
looks like imma have to pick up some stuff.
gotta go
route -
https://search.yahoo.com/search?fr=mcafee&type=C211US0D20151120&p=maps
the good news is,
the crank has been forced out.
literally.
James Randi retires from foundation at age 86 | Doubtful News
he did not want to leave,
yet,
the mess he was about to perpetrate would have been unacceptable .
That was a year ago?
Or perhaps no one has run that test? You're being a bit petulant there, Bear.
test? what test? "we don't need no steekin' tests!"
To re-iterate.
Have you or anyone ever changed your SPDIF cable and had the "presentation" of the sound appear to change as a result? (this assumes you have a "system" and a separate DAC and transport and have actually used more than one cable in the entire time you have owned such gear, otherwise the answer is "N/A")
(Scientific method doesn't care about your goals, in fact it wants to poo-poo on them whenever possible)
Yes but you must abide by the same principle. It's best that you accept when applied in new ways there's always a possibility that what you thought you knew, was wrong It's a problem on here where everyone that claims DBT DBT DBT thinks that somehow they've befriended the almighty principles of science and won't be crushed by the complexity of the world... Curmudgeonlosophy isn't synonymous with innovation.
the level of avoidance and not committing as to my question is intriguing...
I've heard the difference between optical and coaxial. But you can easily measure that because the standard optical is a lossy piece of ****. I can't confess otherwise, but my friend swears his HeavenGate AES cable was way better than some cheap one he started with.
The onus is always on the the original claimant. "Yeah but you CAN'T prove it" doesn't fly. At least if you want to make it past pop-science levels of rigor (which most don't).
It's already presumed that nothing is absolutely settled, because that would require observation of the entire universe (and I'm lumping n-verses an whatever other theories you want into that).
That evidence stuff is soooo closed-minded.
I suppose the question (actually at least half-serious here) is whether science and the scientific method can be relevant to some "universe" besides what has been called consensus reality. When John Curl refers to "my reality", that suggests a departure from the consensus, to me at least.
It reminds me of string theory, with its 10^500 separate theories, and yet wigs like Witten remain fully convinced it is the one true approach.
Does that establish an excuse for his behaviour?
I will freely admit my opinion was that there was a knee-jerk aspect to his initial approach i.e. "wire just can't matter". The initial parameters were poorly negotiated, too bad it didn't go forward. In the end someone like E. Brad Meyer and his bank of parametric equalizers in the chain would probably have had Fremer calling foul.
- Member Areas
- The Lounge
