Can we use it on BIII no SE?
Sent from my iPhone using Tapatalk
Not yet - but I am on it.
Done - B3(barely tested) and B3SE(well tested) beta releases are ready to test at your pleasure.
https://github.com/russwyte/Buffalo-3SE-on-board-firmware/releases
I will update the readme soon - but the B3 switch mapping are the same as current production firmware.
I will also probably work on the build to build both versions at the same time.
Cheers!
Russ
Cheers!
Russ
I just opened up another round of pre-orders.
They will be shipping on or before the week of May 2nd.
I'm wondering if the next generation of Buffalo dac's using the ess 9038 dac
chip will be available as both 2 and 8 channel dacs? I'm recently using three
BIII's in my DSP setup and if the new chip would be an upgrade SQ wise I
wouldn't mind the simplification of using the 8-channel dac instead.
Best regards.
Best regards.
You could use the already available Buffalo 3 for 8 channel applications if you like.
We are working (actually have been for quite a while) on the Buffalo 4.0 but we won't be releasing any details until we are closer to real production, but I can confirm that the same board will work in any combination of channels supported by the chip from 1 to 8. The board is a completely new design to get the most out of the new chip - but will be stacking compatible with IVY-III and Legato.
The new chips are not in production from ESS yet (good thing because the prototype chips have some errors) - but we are prototyping which is the best we can do right now. 🙂
Cheers!
Russ
Cheers!
Russ
Cheers!
Russ
Thanks for the fast reply 🙂
All this is good news for me so I will be waiting for the coming generation, thanks.
Hi TP Guys, just listening to my Buffalo and I like it a lot. I am wondering if you are planning a new dac utilising the new ES9038PRO chip that's been launched?
Just a wishful thought. It will be nice if the upcoming Buffalo IV SE has its mounting holes and power and signal connections in the same places as the Buffalo III SE. That way upgrades would be a breeze for those of us who've already built a IIISE based DAC.
It will be very close. Though it will more closely resemble the BIII - but far more capable and flexible. 🙂 More details as soon as we have things properly tested. Mounting holes and connectors for IVY/Legato will be identical.
Cool. Thanks for the info.
I'm trying to resolve a problem with being unable to achieve any lock above 96k and running through the obvious stuff first.
I understand that it's important to keep the Data/LRCK/SCK I2S cables as short as possible and of equal length but does this also include the MCLK cable if I am running synchronously?
ie should all 4 u.fl cables be the same length?
Thanks.
Thanks.
I will need a lot more data to help you out. 🙂
What master clock frequency(s)
What source?
What firmware?
Sync mode done right requires the new firmware you can find on our site and here:
https://github.com/russwyte/Buffalo-3-3SE-on-board-firmware
Cheers!
Russ
What source?
What firmware?
Cheers!
Russ
Thanks for jumping on this Russ, it's driving me mad.
MCLK is being generated by Ian's FIFO clock board. The frequency is automatically switched from 44.1K to 384K depending upon the input I2S stream. There are various indicator LEDS on the board and these are displaying correctly according to input (everything up to 384k).What master clock frequency(s)
What source?
My regular sources are a pimped up PC and a microrendu. I have also tried a couple of laptops to try to narrow down the problem. I've also tried a few alternative USB > I2s cards (waveio, diyinhk, sonore). The problem is exhibited with all these different sources.
What firmware?
No idea which firmware version but the 2 x DAC boards were bought from you 3 years ago (I guess!). I spotted your updated firmware chip as I was researching this. I ordered a new chip late last week and I'll let you know results here.
Hope this helps ;-)
Crom
You will need to set DPLL bandwidth highest (not low or none) so that it basically does nothing. You will also definitely need the new firmware if you wish to run sync mode.
Yes, I am trying to run sync mode. Yes, DPLL is set to highest (i've read your "freewheeling" comments elsewhere). Firmware's on order so let's see what happens.
Just returning to my original question: I understand that it's important to keep Data/LRCK/SCK I2S cables as short as possible and of equal length but does this also include the MCLK cable...
ie should MCLK be same length as others?
Whilst I'm waiting for the firmware, should I be looking at any other potential issues? In the past I've managed reasonably stable sync-lock as high as 192k - even at 32-bit - but for some reason it is eluding me over the last few months.
Thanks for your help,
Crom
Crom
hi
Crom: I have no problem running sync mode direct from the Sonore USB interface direct to a B-IIIse using the masterclock generated by the Sonore board (it was designed for this). I doubt you will have advantage using Ian's FIFO re-clocking board if using the Sonore USB interface, as the Sonore board already re-clocks the signal via Crystek CCHD-957 oscillators on the isolated side of the USB board. The I2S connections in my setup are u.fl with the masterclock cable being longer as well, so no problem with slightly different length cables. This works fine for me up to 384 PCM and DSD 128.
Crom
- More Vendors...
- Twisted Pear
- Buffalo III - SE
