100W Ultimate Fidelity Amplifier
I have built a couple of those. They work well with the FX100. I just wanted to test the little MOSFET protection circuit with the FH11.
BTW, I hooked it up to my A/B setup and it sounds very good. For someone looking for a little more power from the FX8 circuit this is a good way to get it.
Maybe this is a good combo PSU and protect circuit for FH11?
Hallo andrewlebon.
wich pcb layout Programm u use?
On weekend i have tested KICAD and Express PCB, but i am to dump to import files to
work on it or it is not possible.
I have seen in Juan clip- he works with Sprint Layout you can import files and rearrange
it.
For me it needs to much time to create a schema and work step by step- i am search a
short way to work on Bimos FX8 mod board for example.
If any other can give me advise- all is welcome- thanks.
Cheers Bangla.
Hi BanglaH,
only because I am using😀, you can try eagle, there is a good series of tutorials by Jeremy Blum on youtube. Its a difficult program to get around initially, but once you get the hang of it, it becomes simpler and because of backward compatibility with schematic, there is minimal chance of mistakes. ofcourse trial version is limited to a board size of 80mm x 100mm, but thats good enough for most single pair amps. sprint is way simpler than any program i guess, but does not have compatibility with schematic. you have to check each and every connection in sprint.
reg
prasi
Hallo Bimo and Prasi.
But learn how to make good PCB layout is difficult.
I know that you have many experience in that doing.
My point is beginning to learn with Layout Programms to learn the rules.
If i can put in to Eagle, for example, a Layout i have a point for beginning in shorter time.
Thank you for advise Prasi- will test it on weekend, hope i understand simplicity it
works ;-).
FH11 with modifications suggested by Mr. Miles.
@XRK, could you update schematic with modifications.
@Bangla H, I use sprint layout easy to use but more likely I make mistake while drawing layout. But it's fun once you get hang of it.
I started with eagle and still use it for digital layout.
