Rockford 301s Won't power up
Confirm that you have 0 ohms to ground on the collector of Q2.
Are you sure that you have good solder connections on all of the driver transistors?
No. In fact I was looking at that when I was measuring the emitters and thinking more solder wouldn't hurt.
I think you are on the money about the collector of Q2. I need to resolder it and see what happens. I'm back inside so it's not a problem. The Weller is still setup. I'll hit it real quick.
Solder a small jumper from the collector to pin 16 of the 494.
I was looking at the 201s the first time. It was close but not exact. You can confirm that pin 16 is directly connected to ground before making the connection.
If you have a piece of computer ribbon cable, a strip of that makes a good jumper for low-current applications.
I'm looking in there with a magnifying glass and light and, is it possible you can burn away the leg of the transistor itself? I see that looks like a little bit of the pad and it does have continuity to ground.
I'm wondering if that old Weller tip didn't just burn away what was left of that transistor. I've been trying to put a probe on the leg and it seems as if it's missing. If I have another sub I can use, it might be best to remove that driver.
