Idiosyncratic
Cool word..
That, and ubiquitous..
Ubiquitously idiosyncratic.
Idiosyncratically ubiquitous.
I must sound smarter, no?
I feel it... 😉
John
"When the facts change, I change my opinion;", someone said, "what do you do?" You moved the ground; that moved my "target". The main problem is still there: measuring a small signal in the presence of a much larger signal with a similar spectrum.
I am chatting to lots of people. Most of them agree with me that your experiment is a bad one. I find that encouraging, as some of them know far more about good experiments than I do. If a simple theorist like me can see the flaws in your setup then it can't be very good.
Why don't you just drop this? You have adequately illustrated the point I made; for that I must thank you.
Because it is your interpretation that is so off. For example the shield is part of the cable and it should influence the test. So your discussions undoubtedly contain that filter. that is included in the setup. Numbers?
But if you were actually serious you could do a test yourself to demonstrate.
Max,
Don't worry no one will believe you.
2x4 isn't 2x4.
I think it's for computing board feet from rough cut timber in some cases or maybe just tradition my 1924 house had rough unfinished studs right from a mill and they were 2 X 4.
Next time I order a drink in the US, I'll ask for a 1/6585 cuft shot of bourbon.
I once ordered a 1 cm slice of fois gras at a local shop and they didn't know what to do.
going back and forth
Mr Soibelman,
a standard drink in the US contains a defined amount of alcohol in fl oz.
With help of an alcohol percentage (which in my narrowminded view is a metric unit), it's then converted to a beverage in fluid ounces.
e.g. a shot of whiskey is 1.5 fl oz.
(you lot have been using metric from the beginning, gotcha)
I'm waiting for the pics with no line harmonic spray or other confounders. I remember the AeX article. I've had my share of head-scratchers like putting high crest factor signals into an ordinary Aglient spectrum analyzer, or noise aliasing on my venerable HP dynamic signal analyzer. BTW you mentioned your 20pV again, I thought that was using the correlator that you built (or were going to build). I assume you didn't parallel 900 of those op-amps. Lots more places for things to go wrong.
I would have sliced off an inch, cut that in 5 equal size pieces, to hand you 2 and tell you to PO, creepy foreigner
(cheese with truffle from Italy, not half bad)
It s not trivial since he didnt state the number otherwise than with a remaining division operation if i neglect the 3 power:
I have no idea what you are saying here. Aren't there 12 inch to the foot? Is the ratio in cube therefor not 12^3?
Jan
You are still confused about this.
You seem to be a bit confused.
Everybody is confused, right?
You would have shortchanged me about 0.08 inch. Dutchmen...😡
Jan
Jacco,
I was referring to those simple cups and quarts and gallons and converting those to liters and such. We use cups and liquid ounces but most people here would look at you funny if you gave them a recipe in metric units of grams and liters as you would have. Now I have not problem working in cc's or cubic millimeters and such and do just that when doing something that is a precision measure rather than a rough measure such as gallons and ounces. I surely wouldn't do work on a cylinder head for an engine with English measures, I get out a burrete and measure in CC's and I do the same with mixing chemicals. We just have to use those old English measures as the common person here is a dolt when it comes to accurate measurements.
A 2x4 is still 1 5/8 x 3 5/8 as far as I know Sy, I haven't seen a true 2x4 in anything but a truly old building in a long time. Today you also have to deal with steel studs, the most common building material in office building these days.
Yes pretty good. Another weight and measures story. Last Christmas someone at Whole foods pushed the black truffle button when pricing this cheese and put the pieces in the display at $1500 and up.
Jan
If i ask someone how much cm3 there s in a m3 the answer is straightfowardly 0.000001m3, for how much cubic inches in a cubic foot the answer provided by SY is 1/12^3, in one case the number can be directly computed while in the imperial "system" the answer cant be computed instantly, unless you can answer as fast that it s 0.0005787037037.
It's also handy to know approx 16.4cc in a cuin. Once you get above 4 litres in an engine cubic inches sounds so much better. Esp some of the mad 70s engines...
As someone who pays far more attention to speakers, I find it handier to know that there's about 28 liters per cubic foot.
No I quit at four banks of 25. With transformer and correlator I see more noise from a .05 ohm than shorted but just barely. However I have no practical use for the setup. It was just fun doing it.
I suspect you could try the experiment with one laptop as the source and your usual gig doing the measurement.
I do not plan on showing these measurements until other folks seem to get the same results. They are quite interesting.
Lets not talk too much about crest factor, a very hot subject in selecting loudspeakers. The normal process is to use pink noise with a 20 dB crest factor covering the range under test. The power level is increased until the response deviates by 3 db in any 1/3 (IIRC) octave band due to thermal or other compression and that is the maximum output. Now some manufacturers are measuring the peak amplitude not the RMS. This should give them a number 17 dB higher than the folks who do it correctly. Then there is the technique of using a loudspeaker with a minimum impedance of 4 ohms for most of the frequency range under test and since it never dips below that calling it 8 ohms as permitted in the standard. That gives another 3 dB to the output level for a given voltage. (Power is calculated from applied voltage and rated impedance.) So there can be a 20 dB difference even before the conservative guys give their worst case numbers often another 3 dB. Others just take the 1 watt number add a bit for supposed maximum power and present that. Then there are the folks who just lie!
Makes doing a design quite a bit more difficult. I have one project where the prices for what should be a useful system are ranging from $460,000.00 to above $1,600,000.00. Another ranges from $6,000,000.00 to $10,000,000.00
Well have you followed enough to try it?
Dutchmen
Do tell your next lawyer not to bill you an inch instead of a cm.
I recently ordered a 20 cm piece of salami and the lady put the knife at slightly less than 10 cm. Smiling: "That much?".
Roaring laughter at the counter.
- Member Areas
- The Lounge
