EL84 in triode
have monoblocks 4x EL84 in triode - driven by 2x ecc81 -
The EL84 are on 430v and amp gets hot
Have to replace the trafo so have to decide new anode voltage on the EL84 ...
neg grid voltage a.o.
Virtual Valve Museum has a EL84 on max anode 300V and max anode 550V la=0
The anode of the EL84 (7) is with a 91ohm connected to the grid g2
If the new anode voltage is f.e. 330v does the 91ohm be lowered as well...
Not looking for power cause speakers are 94dB .. ...any hints .....
Max, you better look for an established design if you want to build your own amp. Without the necessary knowledge one can't design an amplifier. If you want to experiment and learn while doing so, start simple with an EL84 and ECC81. Read a good book (the ancient stuf is not so practical), Bruce Rosenblit wrote a nice primer. Have fun!
give it a try anyway..
Anode load resistance 150k ( 75k and 75K 460uF + 460uF in series
Cathode bias -22 v - should be - 24
cannot be more specific cause got the amp ....and discovered was too hot before in my hands
brown spots on trafo and board..it is a 220v design
when on variac decrease voltage sounds much much better .....but extra current comes in sooner or later so replace the trafo seems best options....but need to give the specs for another trafo of course
what about http://www.diyaudio.com/forums/tubes-valves/185823-unexpectedly-good-el84-amp.html
anode on 330v ...
And cathode voltages ....120 mV now variac on 180v) 250-275mV when on 220v (bias pot regulatable)
I mean the output transformer primary impedance. This is important to know if you are trying to figure out what operating point you want your | | EL84 wired triode. Either way you need to get the anode/screen voltage down.
What's is the cathode resistor values? Are the cathode resistors shared?
If you can draw up a quick schematic it would be advisable or at the very least give us some decent pictures to see what we are dealing with here.
do not want to change but get the anode voltage down from 430 to around 330v
We need to know what we are working with before just dumping voltage into heat. This would include all primary and secondary taps on power transformer and the rectifier and filter network. Either trace it out and draw up a schematic or at the very least take a picture most of us can figure it out by that. Without this we are relying on crystal balls.
Once you get your voltage down then you can figure out the best bias condition for you.
Thanks yes should be down....output transformer difficult to measure get 0.5 ohm to .....fluke keeps running ...so how to measure accurately../
Cathode resistors are 10ohm paralled with a 100uf elco
i get the pictures here ...cannot get a schematic yet
primary side of trafo from left to right
1:150v
2: 60v <> 5:60v these 2 are connected
3: 13v
4: 13v
6: 65v
secundary side follows (have to be careful ...not my own and been much too hot.... it is a tiny triode 25 old manley cannot find schematics anywhere)
Ex-Moderator
Joined 2011
With the OPT disconnected from the output tubes and the speaker/load, apply a small AC voltage to the secondary winding say 5Vrms and read the voltage at the primary winding, then we can use the ratio of the voltages to calculate the primary impedance for a given load impedance.
secundairy side - left to right
1 and 3 feeding rectifiers anode 430v
(2 non active)
primary 3 and 4 feed rectifiers for neg bias see above
4 travels to pin 4 of all El84 .. heather
and 6 to pin 4 of 1ste ecc81 ..heather
5: earth
