any thoughts about adding a built in 24mhz clocked usb hub to the input of this device to reclock the usb signal
Like a built in uptone regen usb2412 chip
Is it working at 512 (1024) DSD rate in Linux?
I see that there is some support for diyinhk cards here
https://github.com/lintweaker/xmos-native-dsd
but somewhere is written "DIYINHK USB to I2S/DSD converter [max DSD128]"
I would need this card for testing these rates on my audiolinux OS with a passive "nodac" output filter.
Ok, so could you develop say a 2-way or 3-way digital active crossover on a PC (on Windows 10), then run it via USB in to the XMOS board to convert to I2S, and finally from I2S to say a DIY multichannel Buffalo III DAC? Or even could you use one XMOS board to accept multichannel USB audio, and then run the I2S outputs BACK in to two further XMOS boards to create 2 separate USB outputs (for a 2-way active crossover) to run in to say two Chord Hugos?
I just got the SMSL M8 (uses xmos usb and es9018k2m as well) -- I'm pleased with the sound. I am wondering how a DIY DAC with these boards from diyinhk would sound compared to the SMSL M8. Assuming one uses low noise power supplies, and good transformers.. and installed it all properly.
Im wondering about using this device along with Buffalo III DAC in order to create a multitrack recording device for the PC for my own recordings. how feasable would my idea be ?
The Buffalo III DAC has 8 channel inputs.
Realise this is a DIY forum but.... I would love to see this sold as a complete unit in a decent case with SPDIF/AES/i2s outputs a bit like the Singxer SU-1, and the VU meter visible at the front of the case. Any chance of that happening?
This is the official answer about linux:
"The 768k pcb USB_ID(0x20b1, 0x2009) is the same as our 384k pcb, it should also work."
Rixsta the Buffalo is a sabre32 based DAC. What you want is what I am looking for, a sabre32 based ADC, which acko adc seems to fit the bill. But you need more than one for multi-channel as they are stereo.
diyinhk,
I there the board provide a SPDIF INPUT ? If yes, what sampling rate are supported ?
Does the schematic of the board is provided when we buy it ?
I would like use the Master clock signal coming from my own ADC,
so i think that is possible by connecting it in place of the on board oscillator.
My MCLK work always at 24.576MHz.
For now, i hesitate between your board and the USB streamer...
Thank you in advance.
Could you confirm me (as i read on your web site..) that the blue PCBboard have only I2S output, no INPUT and the green PCBboard have both I2S inputs and outputs ?
Regards.
Frex
Regards.
Frex
Thanks for that it's nice to know someone else wants to do the same thing.Rixsta the Buffalo is a sabre32 based DAC. What you want is what I am looking for, a sabre32 based ADC, which acko adc seems to fit the bill. But you need more than one for multi-channel as they are stereo.
Not met many ...although I'm wanting the multichannel for recording music.
I might just buy something like the RME UFX though it's a great soundcard.
Sent from my SM-G900F using Tapatalk
The ADC I am considering needs to run in Master mode, can this be reprogrammed to operate as slave? I'm guessing yes. thanks
Hello,
I bought one of this board, to try to use it with I2S inputs and external MCLK.
I received it yesterday, and the first thing i can say it that welds quality is poor.
There is obviously manually soldered with excessive solder.
Even a decoupling capacitor was standing because not soldered on one side.
The outline of the board is also badly cut, we can see metallised holes on edge of the board.
I also a little bit disappointed with the lack of any documentation provided.
Only a picture with pin-out on their web site...
I really think that for the price a little more could have to be with.
No matter, i do not have already made tests, but i will post here results of my tests,
i hope in the week.
mcspack,
As you, first i want use it in slave mode but even if it is hardware possible
for the Xmos device i doubt that DIYink would have to change the firmware for that.
Anyway, we can fed our own MCLK in place of on board oscillators easily.
So you will just need to synchronize the LRCK to your ADC LRCK.
I think that is possible using little glue logic.
(But yes, that need some work and time and as you i would really appreciate a real
boards with I2S slave inputs !)
hopkins,
As soon my board is working, i will try it on my linux desktop (Ubuntu 14.04) and
i will let you know what we can expect on it.
Frex
i hope in the week.
mcspack,
hopkins,
Frex
Hello,
i hope in the week.
mcspack,
hopkins,
Frex
I got mine and installed and can confirm it works fine under Linux. Started playing with ecasound to build a 2 way crossover.
I have made progress. See here: http://www.diyaudio.com/forums/twis...rs-digital-crossovers-bbb-23.html#post4760489
I also have the singxer F-1 XU208 interface, but cannot really compare the two at this point, as my setup is different in both cases (the F-1 goes to a Nadja WAF DSP board, whereas I got the multichannel board to implement software crossover). Also, I am not using a very good power supply on the multichannel board, and have not yet fined tuned the software crossover settings. It does sound promising, however. I would be interested in hearing in others' feedbacks.
Hey frex,
i was googleing around the other day and found some other board that could possibly be used as an intermediary between our xmos and our adc, forget the details and what it was called but pretty sure it was a diyaudio link. dont know if it was a reclocker or fifo but it was something similar to that. Struggeling to find it in my history. Anyway the idea was it could be used as a way to run both boards as master?
Hello mcspack,
As you, i looked a lot about USB solution to receive SPDIF or/and I2S data.
The only ones i found is the USBstreamer and the DIYink circuit board i bought
(because USB streamer is much expensive an not DIY friendly for modifications).
The big majority of XMOS board (DIY or not) handle only outputs, no input.
This is only for DAC connexion.
There is JensH on DIYaudio that have built also an isolated that can be connected
to USBstreamer even using the digtial I/O for I2S input.
He has made some hardware modifications on the USBstreamer to replace the MCLK signal.
Frex
Frex
- Vendor's Bazaar
- diyinhk Store
