Hi all!
I have Carrozzeria TS-V017A tweeters which have stated 4 OHM on it. But my multi-meter shows a resistance of 10 OHM. I don't have a crossover for them so will any car audio crossover made for 4 OHM tweeter work with it of do I have to make a custom crossover?
Z differs from Re
DC Re as seen by a multimeter will be lower than real Z
Probably those tweeters have a hidden internal resistor to limit over-abuse😕
Hi Jon, for tweeters the Dt/Dv rating of the cap( which I don't know the meaning very well, but...) is important so the higher the voltage the better.
250 V is a standard ( thou I may use 63V or 100 V ...)
The crossover will be a single 4u7 capacitor. Usually Bi Polar Electrolytic at 25V or more.
So I can not use my Diamond audio hex S6.0S crossovers with these tweeters??
This is strange. Usually a driver with a nominal impedance of 4 Ohm should have a coil resistance between 3 and 4 Ohm (Re). One possibility is that your meter is way off so try measuring a known resistor of a similar value (e.g. 3R3 or 3R9 resistors), and compare the measured vs nominal value.I have Carrozzeria TS-V017A tweeters which have stated 4 OHM on it. But my multi-meter shows a resistance of 10 OHM.
Another possibility is that the tweeters have some internal resistance added, or that they are indeed 12-16 Ohm of nominal impedance (unlikely). Either way a car crossover designed for 4 Ohm won't work with these.
Ralf
Judging on the images I've seen on the net, the specific crossover could have a film cap and a coil in the tweeter part.
Help needed to recreate this crossover:
Ralf
I want to know the circuit diagram which I want to recreate...
I know from the the ratings on caps:
Big round Cap: 15 micro Farad
Square Cap Left: 2.7 micro Farad
Square Cap Right: 3.3 micro Farad
Right and Mid resister: 5.6K ohm
The Left resister is for the switch so not needed: 3.3K ohm
I do not know the values of the coils or how the circuit is connected!
Please provide me a circuit diagram so that I can run my tweeters...
- Tweeter resistance
