Anyone try this TA2022 180wpc board?
Another advert that lies.
It has an absolute maximum supply voltage of 80V (±40Vdc)
The max power is 60W into 8ohms and 90W into 4r0 dummy resistive load.
It is NOT a 180W+180W amplifier !
Not necessarily.
TA2022 is rated 90W RMS per channel, +/- 31V rails, 4 ohms load straight in the Tripath datasheet, so a bridged one can supply 180W RMS into 8 ohms , so only ad error I see is labelling it a 4 ohm capable amp, although they seem to set it straight in ad body, so I wouldn't crucify them just on that.
Since they use two TA2022 per amp, 180+180 W RMS looks quite doable and within ratings.
