Comparing AK4399 to AK4495
Diy-DACs from Ultimate Star
Advantages - relatively inexpensive, and the exhaust is not fancy but good for demo board, good equipment, built on discrete power or the ability to use its power to the OS and primary digital and analogue DAC. Quite good secondary stubs - lt1763 analogue, adp151 digit (are individual for each chip, quartz). The full DAC DAC analog power and oh - embedded discrete shunt regulators. Support DSD (ASIO NATIVE). remote control.
https://ustars.world.taobao.com/category.htm?spm=a31…nTgS&search=y Ultimate Star Shop on Taobao
https://world.taobao.com/item/44710983763.htm?fromSi…0809223.33.QhjfXx full DAC
https://world.taobao.com/item/520401395018.htm?fromS…0809223.28.QhjfXx ак4495 DAC without power
https://world.taobao.com/item/526038366366.htm?fromS…0809223.39.QhjfXx dual ак4495 DAC without power
https://world.taobao.com/item/520834209345.htm?fromS…0809223.30.y1VvmE ак4490 DAC without power
https://world.taobao.com/item/527172582335.htm?spm=a…abe5-391b63f82468 DSD DAC Signalyst
https://world.taobao.com/item/44752822185.htm?spm=a3…a272-d9b95da6abb2 XMOS (suitable and Amanero)
е SITIME (Upgrade SITIME crystal version (two 24.576M, 22.5792M upgrade for ultra-low jitter crystal SIT8208) SiT8208: Ultra Performance LVCMOS Oscillator
https://item.taobao.com/item.htm?spm=a312a.7700824.w…p;id=520832497451 spdif Ак4118
https://item.taobao.com/item.htm?spm=a312a.7700824.w…p;id=523984212824 АК4118 and АК4137
https://yadi.sk/d/42vLgyR-r7mGE body sizes for a full DAC
https://yadi.sk/d/2RXbYbZNr7vJQ jumpers and accessories DAC without power
https://yadi.sk/i/-u_BoE1LrZaPY Jumper dual-card version
https://yadi.sk/i/404E2zyrr9XW6 remote control. activation. the remote control has to be - Apple (Tested model: Model No: A1156 emc no: 2086, ...)
"I made it according to the instructions from the picture. At first clamped two buttons with the first image and the inscription was IR_OK, then clamped the two buttons with the second image and also waited IR_OK. Only after this control started working ..." Dyadya_Fedor
https://yadi.sk/d/uxQLqNosrAaVH alternate logo approved developer Ustars
qchx88@163.com
communication with the developers more, please do not pull in vain! Only on substantive issues. Otherwise, the developer will not respond!
- https://yadi.sk/i/SO73qj1Zrg6wA dual power version - foto
- https://yadi.sk/i/dL955yJtrg7jE сDiscrete Power full version DAC
- https://yadi.sk/i/xog0Q5pyrg7qX ustars DAC output filter
Often referred to diy projects
DIYINHK
AK4495 - I2S over USB Audio JL Sounds
https://cirydac.world.taobao.com/category.htm?spm=a3…ttRM&search=y CIRY AUDIO.
https://shop36043292.world.taobao.com/search.htm?spm…scene=taobao_shop SURE AUDIO
Vega-lab diy-DACs
http://www.lynxaudio.net/%D1%86%D0%B8%D1%84%D1%80%D0…1%80%D0%BE%D0%B2/ LYNX AUDIO
Audio - ALTOR AUDIO ALTOR AUDIO
http://soundex.ru/?app=core&module=members&c…file&id=73480 ENERGETIK
Ôîðóì Âåãàëàá sergey367
Massive Chinese cheap diy As a rule, need to be improved.
https://shop35413239.world.taobao.com/?spm=a312a.772…15080705.4.msV7wX Weiliang.
https://shop35754574.world.taobao.com/?spm=a312a.772…15080705.4.Y7CFAy Юинг.
https://shop66230945.world.taobao.com/?spm=a312a.772…15080705.3.9wvwfh AI DIY
Drivers
https://yadi.sk/d/g2BE0jOkr7CPs xmos weiliang 1.61 , 2.23
XMOS(Ustars Audio).rar ? RGhost ? ????????????? xmos ustars 2.23 (Wave IO), 2.26
Luckit WaveIO modDrivers v3.34.0.7z ? RGhost ? ????????????? xmos ustars 3.34 (мод Wave IO)
Note - Driver Wave II no clicks by DSD on ASIO NATIVE
Quality players
Audio player software "Album Player 2.x" Ïðîãðàììíûé àóäèîïëååð "Album Player 2.x" [1] - Êîíôåðåíöèÿ iXBT.com
https://www.foobar2000.org/ foobar2000
https://www.jriver.com/ jriver
XMPlay Support , https://yadi.sk/d/kg2uku6grYXkm xmplay
Player settings under DSD
http://matrix-digi.com/pdf/DSD_Configuration_Guide.rar Foobar2000, Audirvana. JRiver
http://zvukomaniya.ru/kak-nastroit-dsd-na-foobar2000/ Foobar2000
How to play DSD files on Foobar | PS Audio Foobar2000
By Album Player is simple. Unpack the archive. Of EXTRA folder is copied with the replacement of the main folder and HTPC ASIO folder. Select the output mode you want us to ASIO. Go to the File Formats - ISO.DFF.DSF - Configuration - select NATIVE ASIO
Projects on LINUX
https://www.daphile.com/#download
Sonore ISO2DSD – V.A.M.P.
POWER
From the collective experience of the assembly - powered oh and primary analog power DAC is better suited discrete stabilizers. Primary power numbers - to taste, uses simple Ustars 7805 ... On the boards without power - 10 analogue DAC can be powered from the power ou plus, as
Figure 5 can be powered from the board or ak4118 ak4137
MisterTao: Leading Taobao Agent - Taobao Product - ??????????? ?? Class А OPAMP Power
?????? ????????? ???????/?????????? ?? Taobao ??????, ?? ???????? ???? OPAMP Power
https://world.taobao.com/item/523237220473.htm?fromS…4227019.39.uSsI59 OPAMP Power -CIRY
https://world.taobao.com/item/522950791695.htm?fromS…2014.21088516.0.0 Power STUDER900
https://shop35413239.world.taobao.com/search.htm?q=S…mp;initiative_id= Power STUDER900 Weiliang
https://world.taobao.com/item/1666478416.htm?fromSit…0978983.23.DOEyRq Power OPAMP by Erno (Erno Borbely)
https://world.taobao.com/item/524348240177.htm?spm=a…8516-ad4cd4b4f4e6 LT1963A Power
MisterTao: Leading Taobao Agent - Taobao Product - 78XX?? ????? 5V 12V 15V 18V 24V ????? ?? PCB 7805 Power
How to buy.
Aliexpress. sellers there are other fees. Prices are a little different.
http://ru.aliexpress.com/item/AK4495S-DAC-decoder-fi…etailNewVersion=2 Rose Electronic
http://ru.aliexpress.com/item/DUAL-AK4495S-DAC-decod…/32625139431.html jack Electronic
http://ru.aliexpress.com/store/group/HIFI-DAC-Amplif…8.100006.2.8EO8Ea jack Electronic
TaoBao- through intermediaries.
MisterTao: Leading Taobao Agent - Taobao Product - AK4495S DAC??? ?? ??????????? DSD IIS?? DAC
MisterTao: Leading Taobao Agent - Taobao Product - HIFI???? XMOS U8?? USB ? IIS/DSD ??PCM/DSD xmos
datasheet
https://yadi.sk/i/rjgwOMJYrg27D AK4495SEQ
https://yadi.sk/i/wTiOvucerg29i AK4495SEQ eva board
https://yadi.sk/d/DgIDuYK-rg2Cr AK4137EQ
https://yadi.sk/i/3VSJBCdCrg2Ez AK4118
https://yadi.sk/i/dzv2O1NGrg2Gr LT1763fh
https://yadi.sk/i/3Pf1zLperg2Un adp150
https://yadi.sk/i/xLgLuYYfrg2Lt реле, применяемое в устарсах
https://yadi.sk/i/II0KwmLJrg2Jv LT1963
https://yadi.sk/i/nr6YiRWlrg2QW ора1611
https://yadi.sk/i/TTsAG4o0rg2Ry ad797
https://yadi.sk/i/Z6MhwKvqrg2Tf lt3042
https://yadi.sk/i/PZnaSgLLrg2XK Lynx D70
Useful articles
Çàçåìëåíèå è çâó÷àíèå àïïàðàòóðû About DAC grounding and EMI filters connected. LYNX
Premium Audio Devices | AKM - Asahi Kasei Microdevices Ranging from DAC ADC SRC - AKM
https://yadi.sk/i/TzX0xT5yrZbm4 On the process technology in the production of ak4495 -SE, SEQ and 4490. The official response to the request from AKM lomonosoff. Until 4497 - the top (was) just AK4495SEQ.
Links to the audited stores radiocomponents
https://world.taobao.com/item/36051882640.htm?fromSite=main
Reviews of Ustars (There are many)
AK4399 DAC9 (V1.2) Äåøåâûé Hi-Fi - Ñòðàíèöà 114 Uncle_Fedor
Дий-проекты ЦАП - Ustars, Weiliang и другие проекты, #0 DJ
I am interested in a Dual 4495 board with U8 usb board, is there a step by step guide or at least a complete kit so i can know what i will need and how to put it together?
We collected various Chinese DAC. This option is interesting. It does not require significant improvements, and the sound will be better. Resempler on ak4137 does not necessarily choose. There are simple board to ak4118.
http://www.diyaudio.com/forums/digi...ono-ak4495s-ak4137-mcu-lcd-dac-kit-160-a.html
https://ustars.world.taobao.com/category.htm?spm=a31%85nTgS&search=y
Äèé-öàïû îò Óñòàðñ
Thank you but that link is not good for me.
i want to build this:
32bit 768K Xmos U8 AK4495SEQ AD827 USB Decoder Completed Board YJ | eBay
I need to know what else i need for a complete build. i dont know how many transformers and with what spec and any other requirements
There's another one going for $69... With those distances between electrolytics, smd decoupling caps and DAC chip, you may even have reasonable sound for that money. Plus, there's one of my favourite OP's... assuming it's an original 827 chip, which is very good chip...
You need two transformers.
First one should have 2 separate 9V AC windings - not centre-tapped.
The second transformer should be 2X15V AC, this one can be centre-tapped.
Nick
