Thanks, jackinnj. Do you have any recommendation on value of the capacitor. I have used 100nF film cap as in datasheet but I don't have any instrument to measure noise. As you mention electrolytic I would guess the value would be much larger than 100nF. How about low ESR electrolytic?
I ran this in LTSpice with a 500k resistor as RSet
Gentlemen, sorry for asking an off-topic question.
I would like and evaluate the LINEAR LT3062 LDO regulator.
Its specifications: VIn < 45V, VOut adjustable up to < 40V, output current < 200mA.
Can it be used, for example, as an amplifier's frontend - power-supply?
Does anyone of you have experience with this regulator?
Best regards - Rudi_Ratlos
Thank you, I will try an electrolytic cap to bypass the Set pin at some point.
