fortunantly I never had the "throw it over the wall" experience
I have always sat with the layout guy for parts placement, marked up his copy of the schematic with colored pencil annotations as we worked
usually had a very early review where he fully expected some significant rework
We have mini SMA-only torque wrenches for that. I found it hard to believe but I was told the cal standards specify exact torque especially when working at >10GHz.
Straight from the guy next desk: yes, connector torque is critical for calibrating microwave equipment. The inherent discontinuity in connector mating can be minimized this way. To little torque and the mating surfaces are to far away, resulting in reflections, to much torque and the mating surfaces hit, the connector bends and is then permanently damaged. You should see this guy, he's never mating a connector before gauging it with a special micrometer tool (and he's at less that 40GHz, I'm told that at 110GHz this process becomes a special form of insanity). He has a full kit of torque wrenches, all sizes.
The biggest I had to contend with was LMR 900, that was only 300 foot lengths (IIRC). Had to keep bend radius over two feet. For specials like that, I will don a hardhat, gloves, and safety goggles, and I will put myself in the most critical and most difficult location to help perform the work. Everybody responds much better if the engineer telling them what to do actually gets hands dirty with them, and then gives them the freedom and trust to continue the work by themselves. Once they own the work, everybody is happy.
A man after my own heart. I went further and dragged the mechanical designers up onto rooftops, preferably in the rain to show that, just because they could assemble one of these in a nice warm office didn't make it easy for the guys on site.
In Minneapolis in the winter all the site teams quit to work for telcos who still used equipment huts.
FR4 is good to 2GHz at least if the layup is controlled, although a colleague of mine once wrote in a report 'FR4 is good...for canoes'.
FR4 is fine for anything that doesn't require a known dielectric - like canoes 😀 Just about every different manufacturer's FR4 has a different value... Depends what you are doing! PCB microwave antennas need a very predictable substrate, if you want the best possible link budget...
Yep - it needs to be right, but a stuffing great spanner wielded by someone used to installing sub station transformer is as wrong as it gets... Usual result is the whole assembly spinning until until the cables shear...
Or a stilson 🙂
Serves the designers of the 7/16 right for leaving somewhere a big spanner can go 🙂 . Of course audiophiles will be happy to know it's one area where connector plating material really does make a difference.
If you are buying thousands a month oddly the supplier is very happy to control the layup and give you want you want. We spent about 5 years getting the suppliers under control mind. G200 was too much of a price jump for the bean counters. Happy days.
Yes, general purpose FR4 is good enough for most of you. However, the CTC Blowtorch used Teflon and I am not sorry that I chose it.
However, there are different 'types' of FR4, and some are OK for Parasound, etc.
If you can lay out analogue properly and digital you can do audio... RF is not for the faint hearted... Basic RF is within the realms of PCB design, when you get onto the esoteric stuff with components sculptured out of copper shapes you are in a different league an area not for us mere mortals, I have worked with some of those guys and I am convinced they are from another planet...🙂
Microwave PCBs
My understanding was that it was all done using software since every element (trace, shape even corner) becomes a circuit element. Kind of goes from autoplace and route are more and more meaningless as frequencies go up to suddenly the equivalent simulator is fundamental to even functioning in millimeter wave stuff.
Microwave PCBs
Say goodbye to lumped component models.
A physicist I know had been used to working at low RF frequencies. When he was hired in at TRW he tried to make an attenuator with flat response out to about a GHz. He soldered it together out of little resistors (this was at best the dawn of surface mount) and put it in a little box. It was terrible. He began to appreciate the significant divergence that occurred around that frequency and above.
It makes a difference even at high RF freq. The torque wrench will break or click once when you are at the correct torque setting of the wrench. You need to match the wench to the connector to get the right torques for each connector type. Without the proper tools, you will damage connector mating surfaces and get bad data (and may not know it for awhile).
Microwave pcb material (the grey color material) is very stable in its electrical characteristics but must also be stable in dimension with temp changes. Physical dimensional changes of minute amounts lead to bad results.
THx-RNMarsh
Yes but these obstacles are always in different places, and then you get onto via rules, layer changing rules etc. all different from one design to another... You also have to be aware of cutting your escape routes and blocking routing channels... again skills that are learned... Its OK routing a board with say 5000 connections and getting 90-95% success, then you spend a week trying to clear paths for the remaining routes...
The general consensus from PCB forums such as EDA board and LinkedIn is the same regarding auto routers and placers... they are no good.
As said good PCB design is a skill that is part academic learning and certain skills that are developed by hands on doing layouts.
The boards I am doing now all consist of high current signals with circular Mil connectors so I am having to draw copper pours to get the copper to the inside pins, as well as make sure some signal pairs are broadside routed on adjacent layers, certain signals do not cross because of capacitive coupling issues, all copper to be just the right amount for the current, no more to minimise coupling again all good clean fun, find software that could do this for me (or the engineer) and I would be redundant, luckily it is the other way round and good PCB designers who know there stuff are in demand...
Of course all boards are different, but the rules are not. I would assume chess games are all different to some extend, but not the rules. There are specific strategies for a specific situation, valid for any game and any PCB.
I recently did a switching converter for the first time in my life so I read up all about switching converter PCB design. What do you know - it's the same sensible things as in analog audio!
Proof of the fact that it is not creativity but just a trick to master the unwritten rules: as you say, with lots of experience you get better at it. Just the opposite to creativity.
I grant you the last word.
Jan
The RF types I used to work with and try and herd on occasion in the early 90s were an odd bunch even by my standards. Years later we joked that it was an aspergers research project not R&D. There was a hard core of them that used to say that 'anything under 3GHz was DC'. These days a mobile phone has a 5GHz (albeit flea power) radio in it. It's then you step back and realise what a boon PCs have been to radio engineering and what amazing steps have been taken in integrated silicon processes.
My understanding is that some advanced BiCMOS processes are at the point where uC, DAC and RF power stage can all be one one chip, albeit sub watt levels up to significant GHz. 2.4GHz is boys stuff now.
Progress 🙂
Microwave PCBs
We worked with a group trying to define the shapes as components, they were drafting their boards on an 80s CAD package that let them adjust the component geometries on screen as they laid out the boards. I would presume that these days there are bespoke packages, as said we mere mortals don't get involved with the high GHz stuff.
Progress 🙂
Yeah, 15GHz is well integrated these days. Even R/C models use 5GHz for control now!! While modelling is needed if you are doing anything more than a bit of stripline, the software isn't megabucks anymore. But a lot of skill is still needed in the original visualisation. Machines can't do that for you; my colleague at an EMC lab still sees a lot of bad layouts at any frequency...
We're involved in a lot of SDR (software defined radio) - that's another fascinating technology.
