Texan Rebuild
Texan Current Problem
Have followed Ian Finch's sound advice and measured voltages around both channels with current limiter in circuit.
Results are attached, if anybody can deduce from this why the positive rail current should be in excess of 250mA (quiescent) then your help would be much appreciated.
ML
Right hand picture, TR2. NPN (BC182). 2.5 volts on the base, zero on the emitter = answers on a postcard please 🙂
(clue... the B-E junction when forward biased should be similar to silicon diode in it volts drop)
Guys
Whilst your kind advice is much appreciated, I'm still no further forward. Having replaced and tested Tr2 (102) it has made no difference to the 2.5 volt value, and the removed transistor checks out like two working back to back diodes.
Am I missing something ?
Thanks again
ML
Are you reading this voltage of 2.5 across B and E or are you deducing it from two separate voltage readings, one to the base, one to the emitter, and then subtracting the two.
The first method is the only valid one.
Guys
Thanks again
ML
Have a close look at the colour band on your R31 to make sure it is 4k7 and not 47k. Measure the resistance if unclear.
This shows the typical DC voltages and highlights the magic 600 to 700mv B-E voltage for a forward biased junction.
Martin... if you copy the image and replace all the marked voltages with your measured DC voltages then we might get more of a clue.
If you say you have replaced this problem transistor and you are still seeing 2.5v across B and E then I suspect that the device either has different pinouts to the original or its a fake (PNP instead of NPN) You can easily check that by checking the with your RED meter lead on the base, that you then are able to read the 'two diodes'. One to emitter and one to the collector. The base is the common point, red lead on the base for an NPN.
  • PW Texan.asc
    PW Texan.asc
I asked the OP to make a simple set of measurements with a bulb limiter in place, just measuring all points with respect to ground. There will be some interpretation errors but I think he is using an analog meter or a low resolution digital. (Is that right, Martin?) Accuracy could be poor this way too but still not bad enough to affect V B-E to the tune of 2V on any BJT.
The next logical step was to go around checking abnormal B-E voltages directly as you say Mooly, but 2.5V, if real, does mean bin time. If you recheck the V B-E (or rather Vbe) out of circuit it won't be 2.5V. If the transistor is alive, it's always one diode drop or ~ 0.7V, as others have said.
Interesting that with zero voltage everywhere that I'd expect some small current to be flowing, the quiescent current must be then be zero too or the meter range is set too high to read it.
The reason I say to always check directly on the device is three fold.
Firstly, in the time it takes to make two measurements, circuit conditions (thermal drift) and even the mains voltage may have changed all of which can affect the results.
Secondly, impedance of the circuit matters (and more so if using a cheap low sensitivity analogue meter). The meter resistance itself can upset biasing and give inaccurate results in some cases.
Thirdly, you can get odd readings if for example the print was open circuit somewhere and one of the leads transistor was effectively floating. Placing a meter lead on that point could cause all sorts of weird effects and again give a meaningless result.
And related to this... I assumed the meter would be DVM. Now some analogue meters (AVO8 for example) have the red lead as 'negative' when performing resistance checks compared to the DVM's more conventional red equals positive. This means that diodes conduct when the red lead is placed on the striped end, compared to the DVM where the black lead has to be on the striped end.
So in order to determine if a device is NPN or PNP you have to know your meter. So check a known good device (say a diode) and make sure the meter reads as expected.
Hi Ian,
If we open circuit TR2 B-E in the simulation then we get fairly similar voltages to those I think Martin is describing.
According to the measurements there is a voltage drop of 5 across TR1. That is an excessive amount and you will need to find out why. That would lead to high standing current in the output stage and consequent failures. Possibly that part is faulty or there is a problem with the network around.
Great to have you guys on the case.
A couple of points of clarification. The meter I'm using is analog - a "Smart" meter from way back, Volt, Ohms, Amps etc.
I have measured the voltages in question directly, channel 1 gives base - emitter Tr2 of 0.5 volt, channel 101 gives base - emitter Tr2 (102) of 2.5 volt.
Mooly's simulation is interesting, the value for R29 should be 22 not 220. Lets see what we get when I open circuit Tr2 and measure the emitter voltage...
ML
