One quick point, lay your pi filters out like mine, the signal must pass through the capacitor and not branch off, this again is an important detail. The caps should be next to the ferrite and the signal pass directly through them before going anywhere else.
Sorry for the very late reply, I avoided my computer for a few days and got so many Diyaudio notifications I deleted the lot and this got lost in the process.
The layout looks OK, apart from the separate %v, the trace going round the board negates the isolation, if you put the 5V input connector at the top, you wouldn't have to have that track going round the board.
Again apologies for the late reply...
Any updates on this?
I replaced my computer and now I "hear" the mouse in the speakers. I have to isolate the grounds...
Didn't put the scope on the outputs to check.
It's not only the mouse, there's patterns in the computer activity that I recognize as noise on the speakers.
I am using a USB soundcard.
I have a leftover LM338 ps board and I was thinking of adding a cleaner supply for the board.
I'll try that first, and add a 10R resistor between the grounds and see if that fixes it.
Hi Glad to see you guys are still interested in pursuing it. I have not made the Board.But if anyone is interested I am willing to send the PCB files. Remember though ADuM chip is limited to slow or full speed data rates. That means no sample rates above 96K and adaptive mode transfers
I have not made the Board. But if anyone is interested I am willing to send the PCB files. Remember though ADuM chip is limited to slow or full speed data rates.
Hi and sorry to jump in with a question.
What would be the highest rez format allowed with a ADuM chip based isolator ?
I mean ... 24/96 will pass fine without glitches ?
Thanks a lot to you and all for the very interesting thread.
Kind regards, gino
Kind regards, gino
The question would be, whether the USB receiver is able to handle 24/96 while on 12mbps USB.
For example Tenor 7022 can
Hi and thanks a lot for the very helpful reply.
I said 24/96 because i feel ashamed to say that i am still on redbook files 😱
seriously almost all my collection of music is on cds and some converts on dvd 16/48.
I am not that much on high rez. I see that many isolator top at 12Mbit/s.
I guess the higher speed ones are very complex and so expensive.
Are you using any of these devices maybe ?
Thanks a lot again, gino
Hi again !
will an isolator based on the ADuM4160 chip introduce additional jitter to the usb signal ?
regards, gino
regards, gino
Use USB asynchronous and it does not matter.....
Hi ! thanks a lot !
regards, gino
- Digital Line Level
- DIY USB isolator
