I would like to suggest a few changes.
Omit C6 initially and test what it does after first build.
Replace C9 with a pair of inverse parallel 1n4148
Replace D4+D5 with a red LED to indicate ON. Select R9 to suit.
For C8=3u3F, then C5>175uF
Maximum reliable power is approximately: Sum of all output transistors Pmax @ 25°C divided by 4
i.e. one pair of irf240/9240 gives ~ 150*2 / 4 = 75W per channel.
Choose you supply rail voltage (and mains transformer) to roughly equate to that maximum power.
AndrewT,
I am reading up on LED biasing and I suppose it is less noisy than a plain diode, but people have also recommended using a simple NiMH battery (self recharging) as the bias device and say it sounds even better. Any thoughts on rechargeable batteries as the bias on the LTP current sink?
FX8 without CCS
I think I finally figured out the Apex naming convention🙂
AXn = simple BJT amp with n transistors.
FXn = FET amp with n transistors.
BXn = Big BJT amp with n transistors.??
The more amps he produces, the more inconsistent he will be 😀
But may be the A and B is related to the classification of the driver stage.
AX-11 has also been quite popular, so also the AX-14. Also there are many other popular amps by APEX like studio reference series and also the DC servo mosfet amp, etc.Looking at the post count it seems FX8 is getting very popular among DIYers.
FX -8 has received recent attention here for sure🙂.
Not quite.. What about FX-100?. I still don't get the naming conventions🙁I think I finally figured out the Apex naming convention🙂
That's great to know. Thanks mate. Will go through the whole thread.AX-11 has also been quite popular, so also the AX-14. Also there are many other popular amps by APEX like studio reference series and also the DC servo mosfet amp, etc.
Sent from my Nexus 5 using Tapatalk
This could be a good method to compare amp FR, but always using the same speakers, speakers themselves behaving over entire audible spectrum. Ofcourse I am no expert or even an EE, can the same info be obtained from an oscilloscope or some other means? This could answer bass/ low bass/ low highs/ great highs, etc questions.The sound quality is from my listening impressions with base FX8 on left channel and modified on right channel and I switch back and forth but using right input to amp at all times. Of course in mono is all that makes sense.
There is quantitative data in terms of frequency response measurement with calibrated mic at same position with same speaker, only amp changing. It is measurable difference in bass response and lower HD in mids and highs. For some reason, the lateral FETs have a rising distortion from 1k and up. The same board with the mods and hexFETs have lower distortion. This means it might have been rather high to appear at a speaker (>-40dB or 1%). The shape of the response is pretty much the same above 300Hz, with the hexFET more bass response below by about 1.5dB and deeper extension by a few Hz.
I really need an amp distortion analyzer and would like to make a DIY one somehow - suggestions welcome. I am thinking a USB audio digital interface with a resistor voltage divider network and measure signal on dummy resistor load vs a mic?
Regarding cost: MPSA42 is $1.00 for a bag of 50, genuine IRFP240 and IRFP9240 are $4.50 a pair.
latFET are $15/pair
Reg
Prasi
Hi Ben and XRK,
That would be really nice. Mr. Mile can review it regarding which is the best variant and design. this is what this thread needs, a nice "Table of Contents" sort of.
excellent!
Reg
Prasi
Yes! My "catalog" is simply a folder structure for all Apex Audio designs that I have encountered. Under each folder, I have DATED the images. In order to have something that is usable by our community, my perception is that we need a website that does something similar, adding verbiage, of course.
We see this approach from Pass Labs, etc.
Required Resources:
1) A website
2) One or more admins
3) Setup/Config data capture of "raw" information, scraped from the thread.
4) Additional input / refinement, particularly from Mr. Mile and other SMEs, including Terry and Prasi
5) On-going maint.
Benz2,
Great that you have that, but for now, simply a listing of amp name, and hyperlink to schematic and pcb would be great. This would simply be a list administered by Apexaudio in post #1. As the OP, he has rights to update post #1 as often as he sees fit. Here is an example of how I provide an index with links for all my Foamcore speaker projects to give you and idea:
http://www.diyaudio.com/forums/full-range/223313-foam-core-board-speaker-enclosures.html
If you can provide APexaudio with a post showing the amp and links to schematic, pcb pdf, pcb sprint, pcb Gerbers, and BOM (if available) would be super.
Amp Name and version* / Date* / Schematic* / PCB pdf's / PCB Sprint File / Gerber Files (all, if applicable)
* minimum info is first 3 items
Thanks,
X
Thanks,
X
No one wants to read any more. Instant gratification is the course these days. There is no best amp. Only temporary favorites. The enjoyment is in the building and the learning. There is an excellent search feature in this forum. You will learn a lot more by using it and asking questions.
I have to agree with Still4given entirely
, ("enjoyment is in building and learning" , additionally in my case its -layouting🙂.)
Yes reading is good and helps one pick up itsy-bitsy things that helps one for life long in this hobby, especially thread like this one and slewmaster are gifts to newbies (eager to learn types). Consider this as an advice to all newbie’s from a newbie.🙂
one can browse entire thread and then to quickly locate required amp is where an index helps. Especially for repeat visitors, it saves lot of time.
I totally agree too with reading. I like index so I can come back quickly for details. Otherwise it takes a bit of surfing pages to find it even with search feature.
We either need a proper index, or separate Threads for each amplifier model.
+1 🙂
as a lot of people, I would like to thank every contributors for this interesting thread, it give me appetit for the FX8 amplifier.
I come from Class D amplification.
I took me two days to read carrefully 1/3 of the posts 🙂
I would like to start to build a FX8.
I think I found the right gerber & schematic file
I was able to start a BOM project on Mouser that I'll share
I have few questions to start my project:
I read here about the FX100 PSU. Is it the more suitable/pricely PSU for the FX8?
Is it possible to use a SMPS?
Second question for XRK971:
Thx for your contribution here, as all your contribution it is very positive,
I would like to start building more amplifiers ...
I red somewhere you bought electronic components on alliexpress,
please, could you detail a little bit more? I found electronic components providers on alliexpress, but at this very first step I found the components don't look audiophile....
What kind of electronic components did you buy? Where ?
regards,
Alliexpress NO!!!!Fake parts!!Better to buy:
Farnell element14 France - Composants électroniques
Mouser Electronics - Distributeur de composants électroniques
and many others
and many others
Benz has already made a nice bom with mouser/ digikey part no. You can refer that while making yours for ease.
- 100W Ultimate Fidelity Amplifier
