Joined 2009
It seems to be the Faital 3FE22 16Ohms (according to the ad).
The opening on the back has visible 3 glued layers so the depth is about 1.5inch [2 layers of 0,25 in. HDF for construction of the housing].
From the shape of the enclosure i would say a one time folded horn with an BR opening - TQWT?!
Finalé Audio’s Vivace Minis: Hearing is Believing | Wall of Sound
In the link is written "they measure 32.5” in height, 7.5” in width, and 13” in depth".
The front is angled a little bit backwards and also the top plate is angled.
For the inner dimension H:32",W:7",D:12,5" as a maximum.
I think everything else can be done by a nice simulation and working with AJHorn or LeonardAudioTML...
described in their prose as:
I'm as big a fan of 3-4" full range drivers in a BLH / MLTL design as the next guy, but - hmm, have we heard any of this "defying the laws of physics" from these folks before?Their magic lies hidden in the cabinet design -- a hybrid horn / transmission line -- which we call our Air Cannon Loudspeaker Transmission System. This unique design provides a 10-fold bass gain over a conventional unit. In fact, bass production is close what we'd get if the speaker was equipped with an extra 10" woofer!
Yes. Bernie had a set. They went a while ago.
dave
Joined 2009
Is this a relative of the Frugal Horn? Or the Busch ?
Ive not seen much chat about this driver before either ?
The faital pro drivers has been well received by a few folk here, Xrk being one of them.
High sensitivty, good power handling.
Joined 2009
I don't think I've seen anyone using a large one as a full range? Would be interesting.
Do I recall correctly that you're using an audio nirvana 15"?
Joined 2009
Yes, my main listening is with the AN15, so damn good I stopped building speakers for many years now already but I'm often lurking around the forum for new things that might catch my intetest 😀
Toyed with the idea of importing some back when I had some cash to spare but the postage was a killer.
Probably would have been problematic for my modest listening room anyway.
I like the look f these drivers, do they have bigger brothers with favourable reviews ?
There is a 4in model called 4FE32 (Nd motor and lower Qts) and 4FE35 (ferrite motor). I have not personally used them but hear that they are good. Then there is the 5FE120 which is not a true full range anymore. Great mid or mid bass though. What it does have is very flat response up to 4kHz and 90dB.
http://www.parts-express.com/pedocs/specs/294-1141-faitalpro-5fe120-8-specifications.pdf
Bigun - remind us again as to the enclosure type/size on your AN15s, as well as approx room size?
For new projects that might pique your interest, how about a FAST with 3-4" fullranger of your favorite flavor, and woofers in the 8-10" range?
A7.3 & A12PW certainly work.
Try as I might, I've yet to be sufficiently aroused by an OB or line array.
Joined 2009
http://www.diyaudio.com/forums/full-range/217893-bigun-audio-nirvana-super-15-a.html
I am v interested in the FAST concept too, have my eye on a 5" Brazillian driver recommended by 'X' on another thread. This pro driver has to be suported by a woofer and it runs out of treble, but I can't hear that high so don't care
Forgive me if I should know the answer to this, but ever considered any of the Mark Audio drivers for a FAST? The new Pluvia7 / CHS70 has quite a decent upper mid to top-end register for my ears. Of course, it's no secret that I've used almost every driver in his range since the EL70 - including 2 recent FASTs - and have become acclimated to any idiosyncrasies with which others might attribute them.
Then there's always the Fostex FF85 and 105WK.
Of course, as always, the intended venue and application will always trump (is that now a four letter word?) the most well intentioned suggestions
Joined 2009
The PRV 5MR450NDY also has very low distortion (if that matters to you) and can take 225w without complaining (when high passed at 275Hz).
- Full Range
- What do we know about the Vivace Mini ?
