The Pro is a stereo card this time around.
Given enough interest, and after the stereo Pro design is built and tested, I'll make a PBTL version of it.
Ok I'll check the development a bit more...
Anyway, getting the order/interest list going. Quote the most recent post and add your name to it if you want something.
loafimus: 4 x bare PBTL PCB + 4 x microcontroller
ChuckT: fully assembled stereo Wiener + fully assembled Pro
DawgNo1: 2x stereo 3118 fully built.
jonners: 1x stereo fully assembled Pro
Got a PBTL version half done last night. Wondering what I'm gonna do now with the extra board space gained from ripping out one of the inputs...Ok I'll check the development a bit more...
I'll keep everyone posted.
Pyjamas Before Chris: 1x stereo fully assembled Pro
Hi, I am arranging a group buy in my area and I have 12 assembled tpa3118 and 3 Pro assembled so far. I will confirm the details later.
If we don't order the filter kit, we can specify the load impedance put on the board, is that correct?
May i know what is the output power into 8 ohm for both the pbtl and stereo amp?
Also can it be powered by the $20+ abletec smps ?
Thanks.
Thanks.
Nice... that's a big order. Mind the comment in the first post though, the Wiener Pro is an experimental prototype and there's a chance the first crack at the hardware won't work 🙂 I guarantee you'll get a working board if you pay for one, but there might be delays.Hi, I am arranging a group buy in my area and I have 12 assembled tpa3118 and 3 Pro assembled so far. I will confirm the details later.
Generally I install the provided load impedance (4/6/8/whatever) on a fully built board when I build and test it. And if you order a filter kit, I include the other inductors/capacitors that are needed need to change it to any of the other load impedances.
In theory I could test the card, desolder the output filter and let the end user stuff in the parts that they choose...
Output power depends on the power supply voltage.Hi,
Thanks.
12V supply: 30W peak/15W RMS sine into a 4 ohm load. 15W/7.5W into 8 ohms.
24V supply: 120W peak/60W RMS into 4 ohms, 60W/30W into 8 ohms.
Got a link to the Abletec supply?
Abletec Smps
Guess it won't as the smps has 53v, need a step down to get 24v. 60w with 24v psu is good enough though.
Thanks for the info.
is it possible to order a board with 16 ohm output impedence? or the filter kit already have component to built 19 ohm myself?
I can do that.
I did a 16 ohm board for rsavas (I think), had 33uH output inductors and a film cap value I can't remember off the top of my head.
Pick up a Mean Well LRS-100-24 power supply. Low cost, good quality and costs $25 CAD from Mouser, hopefully similarly cheap on your side of the world.Abletec Smps
Hi Garry,
I would be interested in your recommended PSU pairing if you have one. Does the PSU quality impact performance much?
I can do that.
So it is possible to order 16ohm board and additionally buy a filter pack for future change back to 8 ohm, am I correct?
wushuliu: 1 Pair Assembled PBTL MINUS CONNECTORS - 4 ohm
hepmusic 1 stereo 3118 8 ohm fully assembledAnyway, getting the order/interest list going. Quote the most recent post and add your name to it if you want something.
Indeed low cost SGD26 + shipping this side of the world.
Thanks for the recommendation. Will decide which model to get soon.
Hi Garry,
I use a "TP3005T" linear adjustable supply, branded "tekpower", purchased off amazon for about $90US, set to 19V constant voltage mode. Tried at least 6 diff PSUs, linear and smps, and this offered by far the best sound. I did the testing on my SMSL 3116 amp, but it shoud be just as valid for the wiener, and its playing very well with my new stereo board. the brick that came w/ my asus laptop (19v/6.5a) sounds nice too, but not nearly as good.
Power question: is the ammeter on my PSU a good indication of the power the amp is putting out? Normally its under 100mA@19V, so 1.9W for normal listening volume? Very loud would be maybe 2x that, or maybe 3-4x at the most. I know there is some other stuff at work-- instantaneous power for transients or whatever, but watts in should = watts out right?
The 1D17A and VER2923 actually have near identical saturation currents:Why no Coilcraft love for the Pro? With a name like that...
BK
http://www.icecomponents.com/images/document/PDF/1D17A.pdf
Typical Current vs Frequency - VER2923 Series Power Inductors
The 1D17A doesn't have the same DC current handling capability as the VER2923, but it's still more than adequate - you'll need to run the WP at 36V rails and output a continuous clipped sine wave into a 4 ohm load to overheat them, chances are you'll trip the thermal protection on the TPA3250 chip first.
The 1D17A also let me shrink the board size a fair bit.
I contemplated changing the PBTL Wiener over to 1D17A's, but decided to leave that "deliciously overkill" design alone 🙂
- Group Buys
- "The Wiener" TPA3118 amplifier, group buy #3 + "Wiener Pro" prototypes.
