B1 has died
How odd, my B1 has died, both channels at the same time.
To recollect, this build uses the PSU (SALAS Shunt Reg) from the DCB1 but uses a clone of the original B1 for the buffer.
It was working flawlessly and had been for several years.
I've just completed a Pearl 2 project which works perfectly directly driving my Aleph 4 - so no problems there.
I decided to add the B1 as a volume control and it's died.
I've tried the original CD source and the B1 is definitely the culprit.
I just can't believe that it's coincidence that the B1 has been killed by the Pearl 2.
This post isn't about "What is wrong", it's more about "Why"
Just for reference, a mosfet will be instantly destroyed of you apply 28 V gate voltage. For JFET's I have no personal experience to destroy.
The reason why I know about mosfets is that datasheets only say max ± 20 V but when do I break the fet and what kind of failures do I get? More than 26 V = no mercy.
Yeah, and at least one member has encountered a large turn-on thump:
http://www.diyaudio.com/forums/pass-labs/156397-pearl-two-130.html#post2828745
Perhaps the OP can try measuring and see if that might be an issue.
Dennis
OK, I've finally had a look at the B1 and I'm baffled.
PSU is fine.
Both NFETs on one channel are fine.
