T7498 4ohm
I wonder what would happen if I would connect 4 ohms speakers and 35v supply. Would it burn down or something?
Do you mean the TDA7498 by ST ?
It may depend on the components values on the filter. I run one into 4 ohms at 24V supply without problems.
Get the datasheet and check the 35V is OK for the chip, it will have overheat protection anyway so I doubt you'll damage it.
Replaced with new board, its seems to have much less hiss and no pop sound when turned on. First I was thinkin it wasnt connected properly 😛
