Questions about building SMPS
I think we are getting closer to Nirvana when we are speaking of good powersupply.
Whole Hi end end Audio boils down to how good power supply is Not the gold plated connectors and Oxygen free copper.
Transformers are best but those massive reservoir capacitors and Inherent resistance of coils leaves no choice but to look for exotic SMPS technologies.
Its been an year I am trying my hard luck with Sg3525 and Tlo494,I admit its no easy.Its rocket science,Black art,spiritual,Divine whatsoever to get a neat stable working SMPS.
Difficult part is the transformer yes someone said it. The core material is very tricky.Then comes High frequencies and Parasitic capacitance inductance and all of type of evils rolled up into one is called SMPS.
I really believe using litz wire until 50 kHz it is a myth
We can calculate the skin effect and we would notice the use of normal 0,6 mm diameter wire is just enough.
For pretentious guys it can use silver plated wires.
Mircea.
I have some experience with litz wire but like I said it is a myth until 50kHz.
Kapton tape is just fine but you must pay attention between primary and secondary winding.
I used aluminium tape like un shield but of course, not in short circuit.
Primary winding split in two part.
Mircea.
Mircea.
Search for proximity effect, leakage inductance, and LLC converters!
Proximity effect can induce much higher eddy current in a wire than the current flowing in it normally. A wire in a coil is not only in the field generated by that piece of wire (like in the calculation of skin depth assumed), but the other turns also generate magnetic field which is added. This is not myth, nor only theory. You can heat up an air core coil made of 1 mm wire with only 0.5 A at 50 kHz. Strongly coupled trafos are less sensitive to this, leakage transformers are very sensitive.
Really?
You must to study more or perhaps I have some lack of knowledge.
I'm not talking about resonant mode.
Mircea.
AndrewT, Mylar tape is the typical insulating tape used in transformers. Kapton tape is a step up, higher temperature range and it costs more.
For a cheap solution clear packing tape is usually mylar.
I find that sellotape and similar and the brown packing tape are quite low temperature.
I would not dare use them inside a transformer as interlayer insulation.
The chinese koptan (mispelling of Kapton?) is very cheap and should be of adequate temperature rating, so I asked. It's maybe a bit thin but hopefully will do the job.
Unfortunately I study enough.
My first SMPS was in resonant mod with Ncp1392 driver from ON semiconductors.
Sample of course.
Could you share quantitative details? Voltages, winding geometry, wire diameters, leakage inductance, freq for max power, tested continuous power, tested temperature at continuous power. Did you use solid wire? Did the temperature rise (or power loss in transformer) match calculated one based on DC resistances?
If all answers are yes, and you implemented a high leakage transformer, then you can say you believe neccessity of litz wire is a myth. If not, then your reason is unknown.
But many experience and calculation proves litz wire is neccessary in the cases I mentioned.
My thesys was about designing and prototyping an LLC offline converter operating in a small, closed, plastic box (case of 12V NiCd DeWalt accumulator) capable of generating 120 A at short circuit, 75 A for 1 s at 60 mohm load, 20 A at 12 V for 3 minutes and 8A for 20 min. Calculating and measuring eddy current losses was part of the thesys, and even at 0.1 mm diameter it was comparable to the DC loss.
However the most difficult part was the synchron rectifier. Without any heat sink, in 1 side of a 2 layer PCB, without a ground plane, because power stage+control+output puffer capacitors took place on the same board.
The prototype is still in use in my 1st workplace after 5 years. But this is not the first, nor the last resonant PSU I made.
