Check this one out..
New 8" DVC Subwoofer Speaker 8 Ohm Woofer Eight inch Sub Dual Voice Coil Bass | eBay
too anonimous and they don't ship in Italy....
Hi all
I'm looking for a woofer with following features:
Does it exist?
Not to my knowledge. Any decent woofer of the specs required
costs easily 50 € in Europe without postage. You should consider
second hand locally.
What's the intended purpose?
http://www.ebay.de/itm/Visaton-WS-2...336371?hash=item5683aceff3:g:rccAAOSwyjBW6XHj
edit: This driver isn't bad at all, but it has its limits. I would prefer it
over no name products anytime. If you'd like to build a 2 way then
you will find a 4 ohm version more favorable. I have made a 2 way
with WS 17 E-4 and the driver is totally worth the money.
http://stx.pl/w-22-200-8-mcx.html
I`ve used the 25cm one, decent driver for the money. Specs of 10 units I bought were within 5%.
Please make some example around 50/60€....
I'm thinking to a 2 way system...
If a 2-way, try this Parts Express woofer. It's a very high value Chinese maker. At $5 each you can't go wrong with the price. It also has a good -3dB point vented of 30 Hz and meets your SPL requirements.
Best,
Erik
Best,
Erik
It got a Qts of nearly 1 (0,95), that gives you an extremely boomy and unprecise bass, in a sealed box and even more in BR. Typical one-note-box, plays just the one in the bass.
http://www.lautsprechershop.de/pdf/mivoc/mpa_wm8.pdf
Pushed up against wall you would end up around 90-91db, but not down to 35Hz!! Price is 45 Euro +freight from Strassacker...
Peter
Peter
Comes to think about it, I have these laying in storage)
http://nedlab.com/wp/wp-content/uploads/2014/06/Vifa-P21WO-12-08-woofer.pdf
Further on, I will be in Italy next week. PM me if you want them for cheap....
Peter
Peter
Peerless 8" HDS Nomex ( 830 869) is a good 2 way woofer
that should not make your life a nightmare designing a crossover
in the 2 kHz region. This kind of quality costs around 80 €. Sorry!
I'd seriously consider Peter's offer on Vifa P21 WO. Poly cones
are very forgiving and they don't need complicated XO filters.
If you choose a waveguided tweeter, you will be good to make
the XO point even lower, which is good.
boomy and unprecise bass, in a sealed box ...
You're talking nonsense!
- Cheap woofer with high SPL
