For a pair of 3-way active crossovers, one option I'm considering is a nanoDIGI 2x8 digital crossover teamed with third party SPDIF DACs on the output. But three or four stereo DACs could get very costly unless I used budget ones, and if the quality or price of those didn't work out then I'd be better off with a pair of miniDSP 2x4, due to their built in DACs.
There are loads of really cheap SPDIF DACs about (e.g. amazon UK), and many get decent reviews. But mostly from the general public, and I've no idea what their sound quality is like. At a sightly higher price there are brands I know, like the Fiio D3, which I'd have a bit more confidence in.
Can anyone recommend any budget but high quality SPDIF DACs likely to be available in the UK?
Cheers
Kev
Cheers
Kev
I have those budget SPDIF DACs and also expensive DACs like Benchmark and Chord. I can say they sound somewhat different, but I honestly cannot say which is better. They are cheap, so you can just buy one and see if you like it or not, or if you can tell the sound quality or not. It won't hurt that much @$20-$30, and it may save you a ton.
Many thanks for that info, very encouraging - could well be worth a try thenI have those budget SPDIF DACs and also expensive DACs like Benchmark and Chord. I can say they sound somewhat different, but I honestly cannot say which is better. They are cheap, so you can just buy one and see if you like it or not, or if you can tell the sound quality or not. It won't hurt that much @$20-$30, and it may save you a ton.
Its a good idea to get just one, and I do have a decent HiFi Dac to compare it against. Think perhaps I'll go for some brand that I at least recognise and test it.
Cheers
Kev
Yes, Jriver + sound card is certainly one of the other options I'm considering, I'm a huge fan of Jriver. Though I would only ever use an external sound card, which limits the choices slightly.
However, building a dedicated crossover into the active speaker system has some attraction too. So before deciding, I wanted to investigate likely cost and quality of doing that digitally.
Cheers
Kev
Cheers
Kev
. There is no stopping this trend of "Audiophile PC"
windows media centre is 14 years old
XMBC similar
Jriver is 18 years old
That's pretty blardy mainstream.
I used to feel the same way, but with those figures power supply noise and associated jitter are simply gone. Jitter will show up as noise and @ 116 and above? Fugedaboudit.Yes, Jriver + sound card is certainly one of the other options I'm considering, I'm a huge fan of Jriver. Though I would only ever use an external sound card, which limits the choices slightly.
Cheers
Kev
Wow!!!!!!@##@#/##!!!!!!@@
double wow!!!!!!
Someone that can decode the quality please comment????!!
Yes indeed!!
Maybe this can be used with the minisharc?
I2S input only. Any way of interfacing this with a nanoDIGI 2x8 in-a-box (SPDIF)?
NanoDIGI has an 8 out I2S header on the board if you open it up.
https://www.minidsp.com/products/minidspkits/minidac8
WHen stacked with the Minishark it can be good enough with the big advantage of a good and supported GUI ????
Are the elec cap with smd résistors after for DC blocking ??? (cheap?)
All of the external stuff is expensive and not even close to what you can do with a cheap computer and a lowley Creative or Asus sound card of 116 total snr or better. Truly renders external stuff academic.
What cheapo options would you be recommending? My mobo soundcard went kaput after I upgraded to windows 10
Yes I know, I wanted to upgrade an old XP pro Celeron with good enough muscles for W7... just because I had a licence at hands !
Ah it worked, but for the embeded old video controler ! ... try to work noawdays with a 600x400 resolution ! That's funny, I could add W7 but when I upgraded it for W10 for the fun to see.... W10 said a fundamental component (nx) was not there to allow the upgrade (hardware not compatible) !
You want to fight the global warning and not change every 4 years of personal PC still good enough : go for Linux ! Save your planet and the world ! (and stop to mess with bad audio USB driver too with W PC for your prefered DAC !
This is discussed in another thread here, but my solution(s) are as follows: alas, you might have to buy some new PC.
Both of these options require a Windows PC and I am using JRiver Media Center (JRMC) for the player and DSP solution. I am feeding 2x 3-way speakers so six channels.
Option 1 (probably the most inexpensive): IF your PC has HDMI-out and if you have a HTR that accepts HDMI and does 5.1 or 7.1 outputs, then you have all the "DACs" that you need I bought a (used) Sherwood-Newcastle R-772 for ~ $150.00. Brand new (closeout) you can get similar units for not much more (in USA at least). Many PC's have HDMI out, I use a Pipo X9 which is < $200 new.
Option 2 (more expensive, I chose this for having XLR in/out): Use an external DAC multi-channel such as: MiniDSP's USB Streamer (allows 8-channel ADAT signal output), actual dac is a Behringer ADA8200. These two items cost about $300. I already had enough channels of XLR amps (also Behringer).
I am sure there are many other possible solutions. I like MiniDSP (the company) but I don't think their solutions are any cheaper than the above.
Sent from my NV570P using Tapatalk
- Digital Line Level
- Budget DACs for digital crossover output?
