Most likely some grounding issues. Are you powering it with regulated power suuply?
..use this power supply schematic for the Buffer and Preamp ...
For a pre-amp I would suggest using good quality regulated PSU, preferably shunt PSU.
Example: http://www.diyaudio.com/forums/power-supplies/286425-shunt-regulator-15v.html
With preamp with non regulated PSU you are always going to have some hum..
If it's excessive hum, grounding/shielding of signal cables may also be a factor.
ok ... thanks for advice
Here is another good regulator, and it's +-24V, just like you need:ok ... thanks for advice
http://www.diyaudio.com/forums/power-supplies/164365-class-preamp-psu.html
Yes, right
PSU excellent , the best APEX ... but there is a simpler?
Exactly - you need to lower the output impedance.
Here is a top quality buffer for your purpose.
Valery
you think ... it can be used as a preamp by connecting a potentiometer ?
The simplest, and still good enough would be one zener + one transistor
regulator. or maybe 2 transistors (darlington).
See:
Transistor-Zener Diode Regulator Circuits
Or even simpler - use LM7824 chip (for positive rail) + corresponding negative IC for negative rail.
I would assume you can put volume pot between your buffer, and the pre-amp.
See:
yes....it is simpler
because the volume pot between the buffer and preamp?
Yes, makes sense. I would recommend a 100k pot for the best performance. Input impedance of the buffer is 850 KOhm within at least 300KHz bandwidth.
- Diy preamp for Amplifier IRFP240/IRFP9240
