SONY TA-E1 preamplifier clone
Hi
I need help with a prototype development. Do I need to change something on schematic or pcb?
Schematic is from Sony TA-E1 preamplifier. Sony is made with SMD parts, my version is with TH parts.
I have LTspice simulation(TAE1-ccsbip.asc), and if someone can help I would be very thankful.
Few pictures!
The frequency is 150kHz!!!.🙂
any oscillations at all? i'd be a little surprised, not seeing any small resistors in series with mosfet gates and/or base leads of diamond buffer bjts....
mlloyd1
edit: aaahhh, i see that the second schematic added mosfet gate resistors
After 10 minutes of work quiescent current drops from 42mA to 31.6mA. After that there is small drop and after 53minutes from the beginning quiescent current is 29mA, after 83minutes quiescent current is 28.8mA
viktor1986. Please tell me what is connected to the terminals + RS1, + RS2, -RS3, -RS4 in the NPS1 circuit?? How well does this work with SONY preamp? Why did you decide to build a more sophisticated power supply unit (NPS2)?
Nothing! My plan was to put remote sense wires directly on preamplifer pcb and because of that there is +RS1, +RS2...In that case, I need to cut few lines on pcb(see photo).
Forget remote sense wires(+RS1, +RS2...)...Do not cut anything and use just +V, GND and -V to connect power supply with preamplifer.
Victor, I want to assemble this power supply, and I have a couple more questions for you:
I don’t understand how stabilization of the voltage at the output of the power supply occurs. And what role does the TL431 with the BD140 transistor play? I am not familiar with the inclusion of TL431.
In the circuit of transistors Q1, Q2, Q3, which are connected in parallel, I also do not see voltage-stabilizing elements. I'm just trying to understand how critical this power supply is to the input voltage (AC 24V). In what range can the input AC voltage lie?
