Just for fun: A set of SE mono blocks that fit on top of the speakers, no FB, conventional dual PSU. PSU switch is a key switch with off, filament pre-heat (2.5V), and HT/Filament on positions. Indicator are orange for filament volts and red for 6CA7 bias current. 😛
Wow! 😛
very nice looking pieces, love it!
Very cool, I particularly like the indicator lights and the power/ignition switch.
Love it mate, certainly one of the most unique amps I've seen.
Here is my Pete Millet low mu preamp with transformer volume control and input relays activated by knife switches.
Very steam punk. What is the tube compliment?
It has a 5U4 for the rec tube and the 6080 for the signal path, and 2 EL34s for a constant current source to the 6080. There are many tubes I can swap in depending on how much gain I need and which sounds better.
Gorgeous! Love your work.
My small block V8 got a rebuild. Signal comes in thru exhaust stack. Simple design, 6922 VAS driving three 5687 in PSE. 2.7mHp at the terminals, plenty for an office amp.
Nice djn. I like ur style.
This amp has been in the works for a long time.. It started out as a fairly modest 845 SET amp, cathode biased 845, Edcor CXSE-5K output transformers, and a Hammond 724 power transformer.. Using Rod coleman filament regulators.
Over the past year it's grown into quite the beast. I got a good deal on some Monolith Magnetics S-5 output transformers. I got a custom wound Heyboer power transformer (z-mount), running a bit higher voltage, changed to fixed bias, utilizing a mosfet source follower setup a la Powerdrive (using Toshiba 2SK3564 mosfets). HV B+ rectified using a pair of 6CJ3's.
The amp can run with either 211 power tubes or 845. Pictured with 211's. The meters on the front are measuring cathode current on the power tubes.
I built the amp with the power section in its own chassis, the driver and raw DC supply for the coleman regs are in separate chassis', and I need to rebuild those in nicer chassis', so I'm not even bothering to show those at the moment. I'm just feeling so good about the amp I thought I'd post a pic of the power section. Couldn't be happier with the sound. And I measure 35W output power just before clipping (well into class A2). The guts aren't the prettiest, but it's more of a function over form type situation. I put a lot of time into wiring this up, and it's rock solid. The chassis is from Landfall systems, and the big black heatsink on top is from HeatsinkUSA.
Just weighed this power section, and it comes in 96 pounds! That's just the power section, as I mentioned this power section chassis doesn't include the raw dc supply for the filament regs, and it doesn't include the driver.
I also picked up a nice pair of Klipsh Forte's, made in 1986. They sound great with this amp. Posted of a pic of one of those as well.
Sorry the pics aren't the greatest.
Hello ,
Waouh ... very nice job 😉
"VoXGrandious" - high efficiency 15" Beyma drivers
99db efficient 15" Beyma concentric drivers in 170 ltr enclosures.
The drivers are Beyma 15" concentrics, there is only one. I bought from the US and landed cost me AU$2000. Fortunately the guy who makes my boxes didn't charge too much.
Xovers are external 2nd order on the woofer and 3rd on the tweeter at 1600hz.
DHT2009: Great work!
What type are your output tubes?
thank you MrCurwen 🙂 output tube PE1/100 RTC (mullard made) Base : Septar (1+6 pins)
- Tubes / Valves
- Photo Gallery
