Thermal picture after the concert.
Got one of those FLIR cameras ? -- we have one at work.
Seek Thermal, plug-in for iPhone.
Interestingly enough I found out recently that FLIR makes a device plugin for the iphone as well. Here. For $260 or so I'd be interested to see how functional it is. Could be a bargoon when you compare it to how much a "proper" FLIR costs 😱
IR-filter looks like a film on the lens: https://www.adafruit.com/products/1567
I've heard that you can remove the infrared filter from an old cellphone or digital camera, and get similar images
http://www.instructables.com/id/infrared-digital-camera---the-real-way/
infrared digital camera - the real way
I would not say so. SeekThermal paints different temperatures into different colours, and can show temperatures on the picture, either lowest/highest points, or in the centre.
Oh, I see... the filter method is black and white,so to speak, while the other is color.I get it now.
My completed preamp with tube phono stage in same design as my thorens turntable.
In the housing i fitted passive alps volume control with remote input control.
Build in tube preamp is the Mini-Me.
http://www.diyaudio.com/forums/analogue-source/242855-mini-me-phono-preamp.html
The volume and input indicators are nixie tubes.
http://www.diyaudio.com/forums/tubes-valves/281206-retro-nixie-volume-indicator.html
Next i build Hypex NC 500 amp with tube symmetrical input stage in dual mono with the same design.
amplifier 6n13 two cycle
Kakie tam za lampi? U menya v knizhke (Lampovyi Hi-Fi Ysilitel svoimi rukami), jest lampa 6P13S - Vykhodnyi luchevoi tetrod. Eto ona?
Here is my Pete Millet low mu preamp with transformer volume control and input relays activated by knife switches.
Hi djn. Its ******* fantastic. But did you check the soldering for leaks? You don't want the high-frequency-uneven hertz electrons to soak away.
Seriously I want to make something like this but I lack the creativity.
Nice!
hello DJN ,
nice job , big respect 😉
прошу прощения?
I was wonder if the tubes used actually were 6P13S. I haven't installed Cyrillic alphabet on my PC so I tried to write a short question with latin letters, asking about the type of tube.
6n13 could be 6N13 or 6P13 ....
- Tubes / Valves
- Photo Gallery
