Thermal picture after the concert.
Got one of those FLIR cameras ? -- we have one at work.
Seek Thermal, plug-in for iPhone.
Interestingly enough I found out recently that FLIR makes a device plugin for the iphone as well. Here. For $260 or so I'd be interested to see how functional it is. Could be a bargoon when you compare it to how much a "proper" FLIR costs
IR-filter looks like a film on the lens: https://www.adafruit.com/products/1567
I've heard that you can remove the infrared filter from an old cellphone or digital camera, and get similar images
http://www.instructables.com/id/infrared-digital-camera---the-real-way/
infrared digital camera - the real way
I would not say so. SeekThermal paints different temperatures into different colours, and can show temperatures on the picture, either lowest/highest points, or in the centre.
My completed preamp with tube phono stage in same design as my thorens turntable.
In the housing i fitted passive alps volume control with remote input control.
Build in tube preamp is the Mini-Me.
http://www.diyaudio.com/forums/analogue-source/242855-mini-me-phono-preamp.html
The volume and input indicators are nixie tubes.
http://www.diyaudio.com/forums/tubes-valves/281206-retro-nixie-volume-indicator.html
Next i build Hypex NC 500 amp with tube symmetrical input stage in dual mono with the same design.
amplifier 6n13 two cycle
Kakie tam za lampi? U menya v knizhke (Lampovyi Hi-Fi Ysilitel svoimi rukami), jest lampa 6P13S - Vykhodnyi luchevoi tetrod. Eto ona?
Here is my Pete Millet low mu preamp with transformer volume control and input relays activated by knife switches.
Nice!
hello DJN ,
nice job , big respect
прошу прощения?
I was wonder if the tubes used actually were 6P13S. I haven't installed Cyrillic alphabet on my PC so I tried to write a short question with latin letters, asking about the type of tube.
6n13 could be 6N13 or 6P13 ....
- Tubes / Valves
- Photo Gallery
