Automotive UcD high-quality power amplifier 2x100W
I have not tried it for 2 Ohm.
One instance I use for subwoofer Focal performance p25 db in stereo mode.(2x4 ohm)
Output transistors optimized for low THD and 4 Ohm load. (IRFI4212), case heat dissipation area approximately 700 sq cm (1C/W)
In general, 2 ohms maximum music power must not exceed 100 watts per channel, which does not gives advantages in comparison with the load 4 ohm
Thanks!
few photos.
(Clipping on 3,9 Ohm load on waweform)
