Just for show.
The PAM8403 powered by an 5v 1,5A ps and handle (with properthy) a pair of Panasonic RX A2 Boombox Speakers.
https://youtu.be/TKh0EWHC7Sk
Good with some 4ohms 15W 8" speakers too.
Cheers
Cheers
I love those little amps. I've built many portable units since I started this thread..
Been using 5 volt bank batteries for the power supply. The ElCheepos work better without the low current sense circuitry. The more expensive bank batteries want to shut down because the amp doesn't draw enough current to keep it turned on..
Found these little gems. Perfect for a quick Bluetooth project..
New Mini Bluetooth stereo digital amplifier AMP micro USB powered 2X3W board module free shipping-in Other Consumer Electronics from Consumer Electronics on Aliexpress.com | Alibaba Group
Try a BSC circuit on one. You'll be impressed..
http://diyaudioprojects.com/Technical/Baffle-Step-Correction-Circuit-Calculator/
Loudspeaker Diffraction Loss and Baffle Step Compensation Circuits
Like mine, here is youtube: https://www.youtube.com/watch?v=MvGieVMbY68
@gychang..
I loved the slooow opening of the Altoids tin to unveil the gem inside!
Great build and thanks for sharing..
slooow because I had the camera on the other hand.. but ended up good...
Hi fellas, I also love this amp, my #1 go to amp when somebody ask about DIY amp. Battery powered and all that's needed is to hook up some wires. Great sound for the deal as well.
Here are two of my video:
https://www.youtube.com/watch?v=dJVALUobM7o
https://www.youtube.com/watch?v=BBqbCfpu97E
