Maybe condensed water could do things like this?
I would expect water to only affect one end of the spectrum and/or cause noise.
Well, i am just happy the problem went away, and i am not going to try to reproduce it.
Fair enough. 🙂
Well Colin sent me a pair of his buffer boards to test. I'll let you guys know what I think. Thanks again Colin 🙂
No problem, pleasure and wow that's one hell of an Op Amp, what is it?
A customer tried some GD-Audio ones and said they were rather good.
That's the Sonic Imagery 994.
Might it be Bavmike's Class-A Circuit? ;-)
No it's the Sonic Imagery 994
Hi Bavmike
Is that now your preferred OpAmp?
As I've said on this thread for months, out of all the discrete opamp's I've tried, I like this one the best.
Apologies if I missed something, but I only found one mention about this Sonic Imagery 994 OpAmp from you in this thread (it may be elsewhere you have been posting) ?
http://www.diyaudio.com/forums/vendors-bazaar/190434-hypex-ncore-910.html#post4526975
Good to know you think there is something else out there worth investigating 🙂
Just ordered 25 of them! $10 more than the Burson and Sparkos, so I hope they are good. He was very forthcoming with some additional values to the Input board. He has a broadcast company use them in the same application.
"Hypex's implimentation of there balanced buffer circuit has 4.7M resistor to ground on the input side of the opamp and there is no high frequency rolloff in the feedback path. This resistors Johnson noise becomes the dominant noise source and is slightly audible here in our lab setup using the NC500 buffer board. As our opamps are extremely wideband and fast, we have found that making the 4.7M a 10k to 47K will drop the noise floor about 36-30dB. We and several of our customers have contacted Hypex regarding this and they may of changed this input circuit by now. So just a technical heads up"
hypex ncore
Right on. Who's board do you think they had in their lab?
hypex ncore
Yes. But not sure why Hypex should change their circuit on their OEM board that's specifically designed to use the fixed LM4562, and works perfectly fine.
Yours?
Looks like its a tight squeeze on my board how far does it over hang the edge?
It fits fine. Hangs over the edge a bit but I don't think it matters.
Cheers Mike its going to be tight in the stereo case they butt upto each other with about a 10mm between each, may have to move them back slightly. We are working on our Pre Amp development this week.
I'm not sure how much you will benefit with these over the Sparko's if used with that preamp. The preamp board will be a bigger factor in determining the end sonic signature of the system. There's not enough difference in the sound between the Sparko's and Sonic's that you will likely hear. I was going DAC direct with my experiments and the noise floor of the noisiest component in the system was -130dB. So subtle differences were definitely audible.
- Class D
- Hypex Ncore
