Max screen grid voltages in datasheets
I'm running 6L6GC triode connected. The 6L6GC datasheet says the maximum screen grid voltage is 450V. Are those maximum ratings for DC-condition or for AC-condition? In triode connection the screen grid voltage could easily have higher peaks than this 450V.
Do I understand you correctly saying the voltage limit on G2 is because of prohibiting arcing at the socket? I thought the top connection was for lowering capacitance to obtain higher operating frequencies?
The problem with G2 is the power it has to dissipate. When current increases anode voltage goes down, more current go through the screen grid. In triode mode anode voltage never goes below screen grid voltage, obviously, that's why pentode mode voltage limit on G2 does not apply.
A few things:
1. that circuit runs into class 2, where grid current takes up the slack from a low screen/plate voltage.
2. Triode mode doesn't dissipate too much screen current/power anyway, as mentioned.
3. The voltage rating isn't just because of screen dissipation, or arcing, though those are important factors. Typical screen ratings drop off hyperbolically above the nominal rating (e.g., See RC-26, curve page 98).
For pulsed and current limited operation, the ratings are usually higher: compare ratings as vertical or horizontal deflection amplifier against typical linear amplifier ratings. Of course, that doesn't mean anything if you want to use it in linear amplifier service in the first place...
Tim
