Max screen grid voltages in datasheets
A few things:
1. that circuit runs into class 2, where grid current takes up the slack from a low screen/plate voltage.
2. Triode mode doesn't dissipate too much screen current/power anyway, as mentioned.
3. The voltage rating isn't just because of screen dissipation, or arcing, though those are important factors. Typical screen ratings drop off hyperbolically above the nominal rating (e.g., See RC-26, curve page 98).
For pulsed and current limited operation, the ratings are usually higher: compare ratings as vertical or horizontal deflection amplifier against typical linear amplifier ratings. Of course, that doesn't mean anything if you want to use it in linear amplifier service in the first place...
Tim
