First One - mosFET amplifier module
I don't buy my audio gear based on what graphs says, because graphs will only show what's present but not what's missing, that can only be found out by listening tests and usually there's missing a lot.
It's up to you how you decide what you buy. But that still does not explain why you don't show any test data for those who are interested in this kind of stuff. Don't you have access to test equipment anymore (as you had for v1.2)?
IMHO it is because we still cannot measure the parameters that are important for the reception of sound by the ear/brain system.
We measure what we are able to, and try to relate that to how that influence the reception of sound.
Example:
We can measure harmonic distortion to very low values, but the ear / brain is pretty tolerable to that. Partly because this is part of what musical instruments produce and partly because sound traveling a distance in air will have more harmonic distortion. On the other hand, we discovered that the early digital sounds were horrible, and learned that there was a time domain distortion (jitter) that the ear/brain was not very tolerable to.
But trying to relate all the imperfections in sound reproduction into one plot or figure, that is naive.
First you have to ask yourself why tube amps with disastrous plots sounds fantastic, not all of them of course.
Some of them... I am asking myself - do any of them really sound fantastic? Or is it just a myth and some habit to specific distortion... I have heard disastrously sounding tube amps and have seen a group of people who were really enjoying this disaster. But yet I have to see a tube amp with disastrous plots that have some good sound. Subjective impressions distributed over the web also proven to mean pretty much nothing. If you make & sell the product - it is even less so as you have a bias.
So, the process stays the same - give me satisfactory specs (set of measurements) and then I decide if it is a good candidate to consider for my purpose. Not the other way around. If there is nothing to suggest it fits - no need to worry. The v1.2 started with, as it appeared, selling an engineering approach - it attracted me to the topic. Now when we are at 1.4 a religion is sold. Some may want to buy it. I don't.
And I have heard amplifiers that had REALLY good measurements sounding disastrously.
There are tube amplifiers that sounds really good and none of them has super specs.
That is the hole discussion.. You can have two amplifiers (tubes or SS) one measuring very good and sounding horrible and one not having the best data, but sounding much better.
Has anyone in the US received their 1.4 modules yet? Mine still haven't shown up. 🙁
No, mine have not either, but I ordered mine on January 27th, so I would not expect to see them, at best, until next week. It might take awhile for these to get thru customs. :xeye:
Let me know what your importing costs end up being, hopefully not :tons:
We need to get some listening impressions on this thread... 😱 Not too constructive right now. 😛
Lazy Cat, have not you considered adjusting position of input/output/power connectors for the next versions of amplifier?
Here is an insightful advice from Hypex:
Connectors Everywhere: A switching amplifier has large, very high frequency currents flowing through the ground plane. The inductance of the ground plane at these frequencies allows fairly large voltage differences to appear as measured from one end of the board to the other. If both ends spout wires, you get a nice dipole with a voltage source in the middle. If you see a circuit board with connectors on either end: duck!
Source: http://www.hypex.nl/docs/appnotes/EMI_appnote.pdf
First One - Unboxing
Thought I would be the first to show the rest of the DIY community this fine looking amp module. Can't wait to get started. 🙂 Kudos LC
Hi Lc ,couldn`t get rid of the Problem yet ,the Noise is coming out of the Tweeter.Sometimes it`s kind of pulsating.
Only one channel has a problem? What if you swap the FO modules, does noise follow the same module? Are the calibration values correct? Did you connect them exactly as drawn in User manual schematic?
I'm surprised since all modules passed factory calibration on the test bench, otherwise wouldn't be packed. Me personally installed 8 modules as an upgrade and no noise at 2 cm from tweeter.
Current First One M v1.4 has GND laid-out as best as possible, 5 mm from GND to -SP (GND) and 0 mm from Input GND to GND (direct connection from RCA's GND - no other parts connected to this track). It cannot be routed better, studied from v1.1 to v1.4, so we got no noise, hiss or hum at speaker's drivers membranes. 😉
P.S. First One is Class AB not switching amplfier.
