Hypex Ncore
The NC500 runs at warm to touch case, particularly the stereo config in one case. We have top and bottom vents in the case. All the modules except the Input buffer boards are mounted on a Ally chassis which are screwed down and have thermal paste to connect them to the chassis. They run at the same temp regardless of input. However I had a Sugden A21SE even the knobs got very, very hot!
You must mean "without colouration"? Discolouration means that it has no colour so "without discolouration" will mean that it sounds coloured.
I meant without undesirable artefacts.
Although English is not my native language I believe discoloured means badly coloured. Without colour would be transparent, but as my woofers were coming apart I wasn't able to make that judgement. 🙄
Hmmm... I don't know what was going on in my head. I was diagnosed as being dyslexic as a teenager (though it doesn't really fit..) but I should understand English better than that ! 😀
You're right, when something is discoloured it is is suffering a change in it's usual colour. I think maybe it doesn't quite work in that particular context but yeah... I should have understood your meaning!
